[gdal-dev] crashes at CreateDataSource
Even Rouault
even.rouault at spatialys.com
Tue Jan 5 02:10:54 PST 2016
Le mardi 05 janvier 2016 10:54:57, Gane R a écrit :
> gdal version gdal-1.11.3 - Filegeodbversion 1.4
> OGRSFDriverRegistrar *poR; //Pointer to hold the
> driver registration
> OGRSFDriver *poDriver;
> OGRDataSource *poODS;
> OGRRegisterAll();
> poR = OGRSFDriverRegistrar::GetRegistrar();
> poDriver = poR->GetDriverByName("FileGDB");
> poODS = poDriver->CreateDataSource("sample1.gdb",NULL);
> Here adding layeres and fields and geom
> Finnally closing the dataset OGRDataSource::DestroyDataSource( poODS );
> *OGRCleanup not called.*
> *First time the code works fine, and the second time different .gdb name
> the code crashes at createDatasource.*
> *This is a snippet of code, I get crash at CreateDataSource second time for
> another filename, this code I am trying to put inside a DLL*
> *features created are destroyed.OGRFeature::DestroyFeature( poFeature );*
> Do I use the API correctly? any suggestions, What the cause of this crash
Difficult to say without a full reproducer.
I've just tested the below Python script with the 1.11 branch and FileGDB 1.4
on Linux and it works fine:
from osgeo import ogr
from osgeo import osr
for i in range(10):
ds = ogr.GetDriverByName('FileGDB').CreateDataSource('test%d.gdb'% i)
srs = osr.SpatialReference()
srs.ImportFromEPSG(4326)
lyr = ds.CreateLayer('test', geom_type = ogr.wkbPoint, srs = srs)
lyr.CreateField(ogr.FieldDefn('id', ogr.OFTInteger))
f = ogr.Feature(lyr.GetLayerDefn())
f['id'] = 1
f.SetGeometry(ogr.CreateGeometryFromWkt('POINT (2 49)'))
lyr.CreateFeature(f)
http://www.spatialys.com
