[gdal-dev] PDF when converted to GeoTIFF maps to location offset
Gane R gane.prog at gmail.com
Wed Jan 6 02:32:25 PST 2016
Here is a link to the file
https://drive.google.com/file/d/0B4shTM1bPS5TMDhNMUpkUC04RlE/view?usp=sharing
This the gdalinfo of the TIF file
Size is 5210, 3498
Coordinate System is:
PROJCS["WGS 84 / Pseudo-Mercator",
    GEOGCS["WGS 84",
        DATUM["WGS_1984",
            SPHEROID["WGS 84",6378137,298.257223563,
                AUTHORITY["EPSG","7030"]],
            AUTHORITY["EPSG","6326"]],
        PRIMEM["Greenwich",0],
        UNIT["degree",0.0174532925199433],
        AUTHORITY["EPSG","4326"]],
    PROJECTION["Mercator_1SP"],
    PARAMETER["central_meridian",0],
    PARAMETER["scale_factor",1],
    PARAMETER["false_easting",0],
    PARAMETER["false_northing",0],
    UNIT["metre",1,
        AUTHORITY["EPSG","9001"]],
    EXTENSION["PROJ4","+proj=merc +a=6378137 +b=6378137 +lat_ts=0.0
+lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +wktext
+no_defs"],
    AUTHORITY["EPSG","3857"]]
Origin = (-9640275.525640748400000,3125396.832506576100000)
Pixel Size = (0.113838781929125,-0.113838781929125)
Metadata:
  AREA_OR_POINT=Area
  CREATION_DATE=D:20151203110313-05'00'
  CREATOR=Esri ArcMap 10.3.0.4322
  NEATLINE=POLYGON ((199823.31714503843
305110.51562091778,199397.58689357759 305110.51562091778,199397.58689357759
305420.42164072924,199823.31714503843 305420.42164072924,199823.31714503843
305110.51562091778))
  PRODUCER=TerraGo Technologies Publisher for ArcGIS GeoPDF Export version:
6.7.3.71
Image Structure Metadata:
  INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left  (-9640275.526, 3125396.833) ( 86d36' 0.25"W, 27d 0'55.47"N)
Lower Left  (-9640275.526, 3124998.624) ( 86d36' 0.25"W, 27d 0'43.99"N)
Upper Right (-9639682.426, 3125396.833) ( 86d35'41.07"W, 27d 0'55.47"N)
Lower Right (-9639682.426, 3124998.624) ( 86d35'41.07"W, 27d 0'43.99"N)
Center      (-9639978.976, 3125197.728) ( 86d35'50.66"W, 27d 0'49.73"N)
Band 1 Block=5210x1 Type=Byte, ColorInterp=Red
Band 2 Block=5210x1 Type=Byte, ColorInterp=Green
Band 3 Block=5210x1 Type=Byte, ColorInterp=Blue
Thanks
Gane
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160106/cced56b5/attachment.html>
