[gdal-dev] Vector Tiles in OGR
Even Rouault even.rouault at spatialys.com
Wed Jan 6 05:37:34 PST 2016
Le mardi 05 janvier 2016 21:06:55, Blake Thompson a écrit :
> Petr,
> No one that I know of is currently working on such a tool. It could be a
> little difficult to write as well.
> Each Tile is its own discrete dataset therefore the hardest part would be
> merging of features into the original features across tiles. You could use
> some complicated merging technique, but that could be very expensive.
> If you wanted to simply view vector tile data it could get confusing as
> well since most vector tiles need a buffer when they are used for
> visualization programs.
Do you mean that the coordinates aren't all necessarily clipped to the
[0,extent-1] range ? If so, yes indeed the merging of consecutive tiles can be
"interesting".
http://www.spatialys.com
