[gdal-dev] PDF when converted to GeoTIFF maps to location offset
Gane R gane.prog at gmail.com
Wed Jan 6 23:49:57 PST 2016
https://drive.google.com/file/d/0B4shTM1bPS5TWkVtWDNhMEZtNE0/view?usp=sharing
Here is a link to another PDF with I experience offset shift.
I have not yet tested with prev fix on truk, Will that fix resolve this
also .. or this is something else causing it.
Here is the gdal info of the TIF file
Driver: GTiff/GeoTIFF
Files: Assembled_OGC5.tif
Size is 6136, 6750
Coordinate System is:
PROJCS["WGS 84 / Pseudo-Mercator",
    GEOGCS["WGS 84",
        DATUM["WGS_1984",
            SPHEROID["WGS 84",6378137,298.257223563,
                AUTHORITY["EPSG","7030"]],
            AUTHORITY["EPSG","6326"]],
        PRIMEM["Greenwich",0],
        UNIT["degree",0.0174532925199433],
        AUTHORITY["EPSG","4326"]],
    PROJECTION["Mercator_1SP"],
    PARAMETER["central_meridian",0],
    PARAMETER["scale_factor",1],
    PARAMETER["false_easting",0],
    PARAMETER["false_northing",0],
    UNIT["metre",1,
        AUTHORITY["EPSG","9001"]],
    EXTENSION["PROJ4","+proj=merc +a=6378137 +b=6378137 +lat_ts=0.0
+lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +wktext
+no_defs"],
    AUTHORITY["EPSG","3857"]]
Origin = (-10159780.774000872000000,3896785.272956570600000)
Pixel Size = (2.429487700587336,-2.429487700587336)
Metadata:
  AREA_OR_POINT=Area
  NEATLINE=POLYGON ((662064.91436366527
3643346.4209082974,665783.20008186984 3653923.2074061511,674458.96238262695
3650873.2296965709,670740.67666442238 3640296.4431987172,662064.91436366527
3643346.4209082974))
Image Structure Metadata:
  INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left  (-10159780.774, 3896785.273) ( 91d16' 0.71"W, 33d 0'40.17"N)
Lower Left  (-10159780.774, 3880386.231) ( 91d16' 0.71"W, 32d53'15.14"N)
Upper Right (-10144873.437, 3896785.273) ( 91d 7'58.62"W, 33d 0'40.17"N)
Lower Right (-10144873.437, 3880386.231) ( 91d 7'58.62"W, 32d53'15.14"N)
Center      (-10152327.106, 3888585.752) ( 91d11'59.66"W, 32d56'57.74"N)
Band 1 Block=6136x1 Type=Byte, ColorInterp=Red
Band 2 Block=6136x1 Type=Byte, ColorInterp=Green
Band 3 Block=6136x1 Type=Byte, ColorInterp=Blue
Thanks
Gane
2016-01-06 16:59 GMT+05:30 Even Rouault <even.rouault at spatialys.com>:
> Le mercredi 06 janvier 2016 11:32:25, Gane R a écrit :
> > Here is a link to the file
> https://drive.google.com/file/d/0B4shTM1bPS5TMDhNMUpkUC04RlE/view?usp=shari
> > ng
> Fixed by https://trac.osgeo.org/gdal/ticket/6292
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160107/e030936a/attachment.html>
