[gdal-dev] Update to EPSG database v8.8
Even Rouault
even.rouault at spatialys.com
Wed Jan 13 02:58:37 PST 2016
Just to inform you I've just completed the update to EPSG v8.8 (previous one
was v8.5) in GDAL trunk ( https://trac.osgeo.org/gdal/changeset/32964 ),
libgeotiff trunk ( https://trac.osgeo.org/geotiff/changeset/2714 ) and proj.4
master (
https://github.com/OSGeo/proj.4/commit/832329a9aadbfcb7f46919c903f7672e719d2a82
). (and proposed PostGIS spatial_ref_sys.sql :
https://trac.osgeo.org/postgis/ticket/3427 )
As you can see (proj.4 nad/epsg file is probably the most readable to see the
diffs), It brings a bunch of new SRS, updated TOWGS84 shifts, etc...
Please report if you notice any issue.
Best regards,
Even
http://www.spatialys.com
