[gdal-dev] Error compiling trunk (nitf)
Jeff McKenna jmckenna at gatewaygeomatics.com
Thu Jan 14 11:45:49 PST 2016
On 2016-01-14 3:14 PM, Even Rouault wrote:
> Le jeudi 14 janvier 2016 20:04:02, Jeff McKenna a écrit :
>> On 2016-01-14 3:05 PM, Even Rouault wrote:
>>> Le jeudi 14 janvier 2016 19:54:32, Jeff McKenna a écrit :
>>>> Hi all!
>>>> With today's trunk, I'm getting a compile error, during linking, with
>>>> Windows visual studio 2008:
>>>> Creating library gdal_i.lib and object gdal_i.exp
>>>> nitfwritejpeg_12.obj : error LNK2001: unresolved external symbol "void
>>>> __cdecl jpeg_vsiio_
>>>> dest_12(struct jpeg_compress_struct12 *,struct _iobuf *)"
>>>> (?jpeg_vsiio_dest_12@@YAXPAUjpeg
>>>> _compress_struct12@@PAU_iobuf@@@Z)
>>>> The problem line seems to be in nitfwritejpeg_12.cpp on the 4th line:
>>>> https://trac.osgeo.org/gdal/browser/trunk/gdal/frmts/nitf/nitfwritejpeg_
>>>> 12. cpp#L4
>>>> This line seems to have been added during a change a few weeks ago with
>>>> the comment "Fix One Definition Rule violations"
>>>> https://trac.osgeo.org/gdal/changeset/32062/#file8
>>>> I'm not sure if this is relevant, but my builds use libjpeg-9a
>>>> Please let me know if you have any ideas, thanks,
>>> Jeff,
>>> is this is a fresh checkout / clean build ?
>>> Even
>> Yes very fresh, when I first got this error I deleted the old
>> checkout/folder and did an "svn co" with a fresh new copy.
> Mmm, could you share your precompiled libjpeg-9a includes, .lib and .dll and
> your nmake.opt ?
> Our appveyor bots use internal libjpeg-6b and Tamas builds external libjpeg-6b
> apparently.
Ah, darn version issues (I just assumed that since libjpeg-9a has been
out since 2014 we were all using it).
Digging deeper, I notice that this code is triggered by a
"JPEG12_SUPPORTED" parameter, which I have been setting for years in my
nmake.opt   Disabling that solves this problem for now :)
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
