[gdal-dev] GDAL_WMS/TMS with local CRS and bbox problem
Andre Joost andre+joost at nurfuerspam.de
Fri Jan 15 03:56:26 PST 2016
Am 15.01.2016 um 12:46 schrieb Stefan Keller:
> Hi
> I have a GDAL .vrt from a GDAL_WMS/TMS which was tweaked to
> projection/CRS EPSG:21781 [see below *].
> The problem here is, that the bbox is way too large. It should be
> Switzerland but it's larger than europe. (in 21781 it's lowerleftX
> 480000 loverleft Y 70000 upperrightX 840000 upperrightY 300000)
> How can I configure the correct bbox in the .vrt?
> Or is this a problem at server side config. (http://tile.osm.ch/21781/)?
> In fact I'm wondering anyhow about these current UpperLeftX/UpperLeftY
> numbers...(which somehow work)?
> :Stefan
> <GDAL_WMS>
>    <Service name="TMS">
>      <ServerUrl>http://tile.osm.ch/21781/${z}/${x}/${y}.png</ServerUrl>
>    </Service>
>    <DataWindow>
>      <UpperLeftX>-20037508.34</UpperLeftX>
>      <UpperLeftY>20037508.34</UpperLeftY>
>      <LowerRightX>20037508.34</LowerRightX>
>      <LowerRightY>-20037508.34</LowerRightY>
Those values are the worldwide bounds for EPSG:3857.
If you look at tile http://tile.osm.ch/21781/0/0/0.png, you see half of
the world (without the americas). The bbox for Switzerland can be set
smaller indeed.
HTH,
André Joost
