[gdal-dev] bug report -- cpl_config.h should not be installed
Even Rouault
even.rouault at spatialys.com
Wed Jan 27 09:55:28 PST 2016
Le mercredi 27 janvier 2016 18:42:19, Carnë Draug a écrit :
> Hello
> I am using an email instead of your bug tracker because the later requires
> yet another account on another site (osgeo.org).
> The bug is that cpl_config.h is installed and included from other gdal
> public headers (at least cpl_port.h, not sure if also from others).
> Why this is an issue is an autotools FAQ "Why should config.h not be
> installed?" [1] which also explains how to fix it. Unfortunately, the
> link to the page that also explains why that is an issue is dead but it
> can still be seen from the web archive [2].
> You may not be affected by this issue until you try to make gdal work
> with another project that has the same bug. Then definitions start to
> collide.
> Also, note that this was originally reported 9 years ago [3] and closed
> as fixed (that doesn't look right to me). The bug is still present.
> The autoconf FAQ suggests a fix.
I don't think the issue is so easy to fix unfortunately. See
https://trac.osgeo.org/gdal/ticket/4810 and
https://trac.osgeo.org/gdal/ticket/4282
If it is, a patch is welcome (and even if it hard to fix, a patch is also even
more welcome :-) )
A potential alternative solution that hasn't been mentionned in the tickets
and I'm thinking of would be to have all the #define of cpl_config.h prefixed
with CPL_ . Requires both changes in configure.in and source code that use
those #define.
> Carnë
> [1]
> http://www.gnu.org/software/automake/faq/autotools-faq.html#Why-should-con
> fig_002eh-not-be-installed_003f [2]
> http://web.archive.org/web/20100414095144/http://inaugust.com/post/68 [3]
> https://trac.osgeo.org/gdal/ticket/1589
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
http://www.spatialys.com
