[gdal-dev] Support for measures
Even Rouault
even.rouault at spatialys.com
Wed Jan 27 14:05:36 PST 2016
> BTW, where can I find a comprehensive list of the wkb types? There is an
> old ISO SQL/MM Part 3 pdf in the web but it is old and seems to be
> incorrect too. libspatialite has a header file that has many but not all
> that ogr_core.h has.
I see I had linked
https://github.com/postgis/postgis/blob/svn-trunk/doc/bnf-wkb.txt
into
https://trac.osgeo.org/gdal/wiki/rfc49_curve_geometries
Also listed in http://portal.opengeospatial.org/files/?artifact_id=25355 (
OpenGIS Simple Feature Access Part 1 : Common Architecture,v 1.2.1) , pages
63-64.
Regarding your addition "ICreateLayer, which all(?) drivers implement,
--> no, there are many read-only drivers
" have geometry type as an argument. The method should call CPLError() with
CPLE_NotSupported and return NULL if the driver does not support measures.
Similarly for ICreateFeature and ISetFeature. ",
my point with adding the new capabilities was that drivers that wouldn't
advertize the M capabilities would never see a M or ZM geometry / geometry
type passed. See what the (non-virtual) methods
OGRLayer::SetFeature(),CreateFeature() and GDALDataset::CreateLayer() do for
curve geometries. Similar things could be done for M.
http://www.spatialys.com
