[gdal-dev] Support for measures
Peter Halls p.halls at york.ac.uk
Thu Jan 28 00:58:06 PST 2016
Ari, Even,
      one potential solution where M data are present but not supported by
the Geometry type would be to add M as a user defined attribute, as is done
for Z values in some drivers / packages.  This preserves both the geometry
integrity and the data.  Should the user wish to 'upgrade' the dataset to a
full xyzm structure at some future date, this is then their explicit
decision and can take proper account of format capabilities, etc.
       There may need to be a debate about what the replacement M attribute
be called, of course!
Best wishes,
Peter
On 28 January 2016 at 08:23, Ari Jolma <ari.jolma at gmail.com> wrote:
> 28.01.2016, 00:05, Even Rouault kirjoitti:
> Thanks for the pointer to the geometry codes in SF Common Architecture,
> somehow I overlooked it.
> my point with adding the new capabilities was that drivers that wouldn't
>> advertize the M capabilities would never see a M or ZM geometry / geometry
>> type passed. See what the (non-virtual) methods
>> OGRLayer::SetFeature(),CreateFeature() and GDALDataset::CreateLayer() do
>> for curve geometries. Similar things could be done for M.
> Hm. For example shape driver raises an error if the geometry type is not
> supported. I don't know what scenario would lead to that.
> Assume that the user has data in GDAL with measures. She decides to save
> that using a driver, which does not support measures. The impact is that
> the measures are stripped out, which is ok if the data is discarded
> immediately after that but not if she wants to still do something with the
> measures. I'm not sure if documenting the side-effect is enough. However,
> the convert to non linear geometries is already there and this would follow
> that pattern. I guess this is a part of the bigger discussion whether we
> consider GDAL as a data storage for interactive tools for example or as a
> data processing library.
> Ari
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Peter J Halls, PhD Student, Post-war Reconstruction and Development Unit
(PRDU),
                      University of York
Snail mail: PRDU, Derwent College, University of York,
                Heslington, York YO10 5DD
This message has the status of a private and personal communication
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160128/868730bb/attachment.html>
