[gdal-dev] Maximum geometry size for JML driver
Even Rouault even.rouault at spatialys.com
Thu Jan 28 01:42:14 PST 2016
Le jeudi 28 janvier 2016 10:33:49, Jukka Rahkonen a écrit :
> Even Rouault <even.rouault <at> spatialys.com> writes:
> > Hi Jukka,
> > could you provide the file or the source file used to generate it ? In
> theory,
> > the driver should be able to process any valid file. The checks are meant
> > to detect things like
> <veeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeery_loooooooong_tag_name>
> > that could result in denial of service, but there must be something
> > wrong.
> And
> > you don't get that with GML where there are similar checks ?
> > Even
> Hi,
> I had a new look on the data and prepared a dataset for testing
> http://latuviitta.org/downloads/big_polygon_jml.zip
I downloaded it and don't see any issue. But it looks like it is the one
written by GDAL
> The issue happens when GDAL reads JML file that is written by OpenJUMP.
> There is no errors if I convert the data into JML format with ogr2ogr. Main
> difference between those files is that GDAL writes the polygon geometry as
> one line but OpenJUMP is writing it formatted with line breaks and lots of
> white space
>           <geometry>
>                 <gml:MultiPolygon>
>                   <gml:polygonMember>
>                   <gml:Polygon>
>                     <gml:outerBoundaryIs>
>                     <gml:LinearRing>
> <gml:coordinates>193588.34496920794,7005684.6655854415
> 193632.06812505925,7005834.808810625
>                         193608.4497544446,7005874.299165146
> -Jukka Rahkonen-
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
http://www.spatialys.com
