[gdal-dev] OGRPoint: fundamentals
Even Rouault
even.rouault at spatialys.com
Fri Jan 29 01:13:11 PST 2016
Le vendredi 29 janvier 2016 08:55:37, Ari Jolma a écrit :
> A question about OGRPoint.
> There are copy constructor, assignment, and clone. Shouldn't these do
> basically the same thing but with a bit different syntax?
Yes they are supposed to do the same thing and hopefully the implementation
does that currently.
> By the same
> thing I mean that the new point or assignee should have the same flags
> (is_empty, is_3D, is_measured), same coordinate values, and same spatial
> reference?
Yes
http://www.spatialys.com
