[gdal-dev] gdal_proximity: possible bug
Filipe Dias filipesdias at gmail.com
Sun Jan 31 01:39:43 PST 2016
I used gdal_proximity on a raster and did not pass the "Values" parameter
because in the help file it said " all non-zero pixels will be considered
target pixels.". The result was an incorrect Distances raster. Afterwards I
set the "Values" parameter and it worked as expected.
I reported this initially in the QGIS bug tracker, see more here:
http://hub.qgis.org/issues/14115#change-67271
I'm using GDAL 1.11.2.
Is this really a bug? Should I open a ticket?
Thanks
Best regards
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160131/ce98572d/attachment.html>
