[gdal-dev] Amplitude virtual bands for complex datasets ?
Julien Michel
julien.michel at cnes.fr
Mon Jul 4 05:32:01 PDT 2016
PS: any comments welcome, I am not really familiar with gdal coding
style & arch.
Julien
Le 04/07/2016 à 14:30, Julien Michel a écrit :
> Hi,
> Started the work here :
> https://github.com/OSGeo/gdal/compare/trunk...jmichel-otb:enhance-complex-datasets
> For now, recognizes the following syntax :
> gdal_translate -srcwin 1000 1000 1000 1000
> DERIVED_SUBDATASET:COMPLEX_AMPLITUDE:s1a-s6-slc-vv-20150619t195043-20150619t195101-006447-00887d-001.tiff
> ~/tmp/test.tif
> I need to see about exposing those derived datasets properly.
> Antonio, I copied one of your pixel function for fast prototyping, I
> hope you do not mind. Of course upon completion of this work we should
> merge properly all your pixel functions with proper
> credits/copyright/licence. Thing is I did not know where to put them
> within gdal.
> Regards,
> Julien
> Le 04/07/2016 à 11:06, Even Rouault a écrit :
>> Hi,
>>> To check if I understood well :
>>> I will create a driver that will recognize the
>>> "DERIVED_SUBDATASET:Amplitude:original_datasetname" syntax. This driver
>>> needs to now if "original_datasetname" is of complex type (to report it
>>> can open it)
>> That or we could also possibly accept non-complex types (assume
>> imaginary part
>> = 0). Antonio's functions handle complex & non-complex AFAICS
>>> , and will also expose the derived band somehow (can I
>>> benefit from the CreateDerivedBand API,
>> If you write it, yes... (it doesn't exist yet if I wasn't clear)
>> If you follow the VRT pixel function road, that's a matter of
>> building a on-
>> the-fly VRT dataset.
>> http://www.gdal.org/gdal_vrttut.html#gdal_vrttut_creation could
>> possibly be
>> used. But AFAICS setting the pixel function name isn't supported.
>> Could be
>> done by implementing CPLErr VRTSourcedRasterBand::SetMetadataItem(
>> const char
>> *pszName, const char *pszValue, const char *pszDomain ), similarly to
>> what
>> VRTSourcedRasterBand::SetMetadataItem(...) handles for vrt sources.
>>> and the pixel functions from Antonio ?).
>> Would make sense to internalize this code (uses X/MIT license)
>>> Also, "original_datasetname" can be a subdataset itself.
>> Yes, that shouldn't matter to the driver. It is just a string that it
>> provides
>> to GDALOpen() (some care must be taken when parsing
>> DERIVED_SUBDATASET:algname:original_datasetname, since
>> can have columns too)
>>> There should also be a mechanism that will report the existing
>>> DERIVED_SUBDATASETS upon query (this I did not get yet).
>> Implement in GDALDataset, the following method (from GDALMajorObject)
>> virtual char **GetMetadata( const char * pszDomain = "" );
>> char **GDALDataset::GetMetadata( const char * pszDomain = "" )
>> if( pszDomain != NULL && EQUAL(pszDomain, "DERIVED_SUBDATASET") )
>> // some stuff. Be careful that ownership of returned char**
>> belongs
>> // to the dataset object
>> else
>> return GDALMajorObject::GetMetadata(pszDomain);
>> As well as :
>> virtual char **GetMetadataDomainList(); to report DERIVED_SUBDATASET
>> when it
>> makes sense (contrary to GetMetadata(), ownership of the returned char**
>> belongs to the caller)
>> Even
Julien MICHEL
CNES - DCT/SI/AP - BPI 1219
18, avenue Edouard Belin
31401 Toulouse Cedex 09 - France
Tel: +33 561 282 894 - Fax: +33 561 283 109
