[gdal-dev] Geotiff FillEmptyTiles with no data value?
Daniele Romagnoli
daniele.romagnoli at geo-solutions.it
Wed Jul 6 06:19:28 PDT 2016
Hi Even,
has this improvement also being backported on previous versions (as an
instance 2.1.x, 2.0.x)?
Cheers,
Daniele
On Tue, May 10, 2016 at 3:29 PM, Even Rouault <even.rouault at spatialys.com>
wrote:
> Le mardi 10 mai 2016 09:22:19, jramm a écrit :
> > Hi
> > I have made changes to FillEmptyTiles so that if nodata is set, then it
> > will always fill with nodata, otherwise 0.
> > I have attached the raw diff...I have no idea how to submit a change
> > request/review etc?
> > fillempty_nodata.diff
> > <http://osgeo-org.1560.x6.nabble.com/file/n5265514/fillempty_nodata.diff
> I've committed in trunk a more complete version of your patch since on
> reflection there was also the case of non power-of-two bit depths to
> handle.
> Patches are better handled as attachments to Trac tickets.
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Ing. Daniele Romagnoli
Senior Software Engineer
GeoSolutions S.A.S.
Via di Montramito 3/A
55054 Massarosa (LU)
Italy
phone: +39 0584 962313
fax: +39 0584 1660272
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160706/5adfdaf8/attachment-0001.html>
