[gdal-dev] Failure Building GEOS on Windows w/Mingw
Even Rouault even.rouault at spatialys.com
Thu Jul 7 09:49:15 PDT 2016
Le jeudi 07 juillet 2016 18:31:30, William Kelly Magee a écrit :
> Hello
> I am using GDAL-1.11.1 and have built it to use GEOS successfully on
> Linux.  I need to build the same on Windows and am using Mingw32.  No
> problem with GDAL but am running into an issue building GEOS on Windows
> using Mingw.  I have searched the GEOS site but cannot find a solution.
Not sure if that's what you meant by "site", but in case not, there's a
dedicated GEOS mailing list :
https://lists.osgeo.org/mailman/listinfo/geos-devel
http://www.spatialys.com
