[gdal-dev] Building gdal with Oracle Developer Studio 12.5 on solaris 11
Michael Smith michael.smith.erdc at gmail.com
Fri Jul 8 08:25:40 PDT 2016
I've only compiled GDAL on solaris using the gcc compiler. You might want to
try that.
Mike
Michael Smith
Remote Sensing/GIS Center
US Army Corps of Engineers
From:  gdal-dev <gdal-dev-bounces at lists.osgeo.org> on behalf of Andrew
Watkins <andrew at dcs.bbk.ac.uk>
Date:  Friday, July 8, 2016 at  11:17 AM
To:  <gdal-dev at lists.osgeo.org>
Subject:  [gdal-dev] Building gdal with Oracle Developer Studio 12.5 on
solaris 11
> Hello,
> I know it crazy, but any pointers would be great.
> I am trying to build GDAL 2.1 using Oracle Developer Studio 12.5  (formally
> Sun Studio12) on Solaris 11, but it fails at first CC.
> ./configure CC='cc -m64' CXX='CC -m64' CPPFLAGS=-m64 CXXFLAGS=-m64
> --without-libtool
> GDAL is now configured for x86_64-pc-solaris2.11
>    Installation directory:    /usr/local
>    C compiler:                cc -m64 -g -fPIC
>    C++ compiler:              CC -m64 -m64 -fPIC
>    LIBTOOL support:           no
>    LIBZ support:              external
>    LIBLZMA support:           no
>    cryptopp support:          no
>    GRASS support:             no
>    CFITSIO support:           no
>    PCRaster support:          internal
>    LIBPNG support:            external
>    DDS support:               no
>    GTA support:               no
>    LIBTIFF support:           internal (BigTIFF=yes)
>    LIBGEOTIFF support:        internal
>    LIBJPEG support:           internal
>    12 bit JPEG:               yes
>    12 bit JPEG-in-TIFF:       yes
>    LIBGIF support:            internal
>    OGDI support:              no
>    HDF4 support:              no
>    HDF5 support:              no
>    Kea support:               no
>    NetCDF support:            no
>    Kakadu support:            no
>    JasPer support:            no
>    OpenJPEG support:          no
>    ECW support:               no
>    MrSID support:             no
>    MrSID/MG4 Lidar support:   no
>    MSG support:               no
>    GRIB support:              yes
>    EPSILON support:           no
>    WebP support:              no
>    cURL support (wms/wcs/...):yes
>    PostgreSQL support:        no
>    MRF support:               yes
>    MySQL support:             no
>    Ingres support:            no
>    Xerces-C support:          no
>    NAS support:               no
>    Expat support:             yes
>    libxml2 support:           yes
>    Google libkml support:     no
>    ODBC support:              no
>    PGeo support:              no
>    FGDB support:              no
>    MDB support:               no
>    PCIDSK support:            internal
>    OCI support:               no
>    GEORASTER support:         no
>    SDE support:               no
>    Rasdaman support:          no
>    DODS support:              no
>    SQLite support:            yes
>    PCRE support:              no
>    SpatiaLite support:        no
>    DWGdirect support          no
>    INFORMIX DataBlade support:no
>    GEOS support:              no
>    QHull support:             internal
>    Poppler support:           no
>    Podofo support:            no
>    PDFium support:            no
>    OpenCL support:            no
>    Armadillo support:         no
>    FreeXL support:            no
>    SOSI support:              no
>    MongoDB support:           no
>    SWIG Bindings:             no
>    Statically link PROJ.4:    no
>    enable GNM building:       no
>    enable pthread support:    yes
>    enable POSIX iconv support:yes
>    hide internal symbols:     no
> $ gmake
>  (cd port; gmake)
>  gmake[1]: Entering directory `/tmp/gdal-2.1.0/port'
>  CC -m64 -I/tmp/gdal-2.1.0/port -I/tmp/gdal-2.1.0/gcore -I/tmp/gdal-2.1.0/alg
> -I/tmp/gdal-2.1.0/ogr -I/tmp/gdal-2.1.0/ogr/ogrsf_frmts -I/tmp/gdal-2.1.0/gnm
> -I/tmp/gdal-2.1.0/apps -m64 -fPIC  -Wall -Wextra -Winit-self
> -Wunused-parameter -Wformat -Werror=format-security -Wno-format-nonliteral
> -Wshorten-64-to-32 -Wlogical-op -Wshadow -Werror=vla -Wnull-dereference
> -Wduplicated-cond -Wunused-private-field -Wmissing-prototypes
> -Wmissing-declarations -Wnon-virtual-dtor -Woverloaded-virtual
> -fno-operator-names  -DOGR_ENABLED -m64 -I/tmp/gdal-2.1.0/port
> -DGDAL_COMPILATION        -DHAVE_CURL -DHAVE_LIBZ -I/usr/include/libxml2
> -DHAVE_LIBXML2 -DUSE_ONLY_CRYPTODLL_ALG -c -o cpl_conv.o cpl_conv.cpp
>  CC: Warning: Option -fno-operator-names passed to ld, if ld is invoked,
> ignored otherwise
>  "cpl_conv.cpp", line 225: Error: The function "snprintf" must have a
> prototype.
>  "cpl_conv.cpp", line 919: Error: The function "atoll" must have a prototype.
>  "cpl_conv.cpp", line 942: Error: The function "atoll" must have a prototype.
>  "cpl_conv.cpp", line 965: Error: The function "snprintf" must have a
> prototype.
>  "cpl_conv.cpp", line 994: Error: The function "atoll" must have a prototype.
>  "cpl_conv.cpp", line 1056: Error: The function "strncasecmp" must have a
> prototype.
>  "cpl_conv.cpp", line 1255: Error: The function "snprintf" must have a
> prototype.
>  "cpl_conv.cpp", line 1303: Error: The function "snprintf" must have a
> prototype.
>  "cpl_conv.cpp", line 1342: Error: The function "snprintf" must have a
> prototype.
>  "cpl_conv.cpp", line 1348: Error: The function "strncasecmp" must have a
> prototype.
>  "cpl_conv.cpp", line 1349: Error: The function "snprintf" must have a
> prototype.
>  "cpl_conv.cpp", line 1940: Error: The function "strcasecmp" must have a
> prototype.
>  "cpl_conv.cpp", line 1942: Error: The function "strcasecmp" must have a
> prototype.
>  "cpl_conv.cpp", line 2131: Error: The function "strcasecmp" must have a
> prototype.
> prototype.
>  "cpl_conv.cpp", line 2137: Error: The function "strcasecmp" must have a
> prototype.
>  "cpl_conv.cpp", line 2381: Error: The function "strcasecmp" must have a
> prototype.
> prototype.
>  "cpl_conv.cpp", line 2521: Error: The function "strcasecmp" must have a
> prototype.
> prototype.
>  "cpl_conv.cpp", line 2591: Error: The function "symlink" must have a
> prototype.
>  "cpl_conv.cpp", line 2612: Error: The function "strcasecmp" must have a
> prototype.
>  "cpl_conv.cpp", line 2613: Error: The function "strcasecmp" must have a
> prototype.
>  "cpl_conv.cpp", line 2655: Error: The function "strcasecmp" must have a
> prototype.
>  "cpl_conv.cpp", line 2656: Error: The function "strcasecmp" must have a
> prototype.
>  Compilation aborted, too many Error messages.
>  gmake[1]: *** [cpl_conv.o] Error 2
>  gmake[1]: Leaving directory `/tmp/gdal-2.1.0/port'
>  gmake: *** [port-target] Error 2
> Thanks,
> Andrew
> Andrew Watkins * Birkbeck, University of London * Computer Science *
> * http://notallmicrosoft.blogspot.com *
> * UKOUG Systems SIG Chair *
> * UKOUG Tech committee *
> * tel: 020 7631 6720 *
> _______________________________________________ gdal-dev mailing list
> gdal-dev at lists.osgeo.org http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160708/baa19e84/attachment-0001.html>
