[gdal-dev] Call for discussion on RFC 63 : Sparse datasets improvements
jramm
jamessramm at gmail.com
Sun Jul 10 02:07:00 PDT 2016
Even Rouault-2 wrote
> For GeoTIFF, the unit of query remains the block. So if a block is missing
> is
> present, it computes how many pixels of the window of request intersect
> the
> block, and count them as present.
> Imagine that you have a raster of dimensions 20x20, with tiles of size
> 10x10.
> Imagine the first block (pixels 0,0 to 9,9) is missing. And you call
> GetDataCoverageStatus() with (5,5,15,15). Then you will have a
> contribution of
> 10x5 valid pixels from the top-right block, 5x10 from the bottom-left
> block
> and 10x10 from the bottom-right block, hence a non-null percentage of 200.
> 225. * 100 = 88.9 %
Ah ok, makes sense.
Having SPARSE_OK=YES mean that gdal_translate will actually skip null blocks
is a good additiona also - more intuitive.
View this message in context: http://osgeo-org.1560.x6.nabble.com/gdal-dev-Call-for-discussion-on-RFC-63-Sparse-datasets-improvements-tp5275443p5275600.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
