[gdal-dev] Call for discussion on RFC 63 : Sparse datasets improvements
Kurt Schwehr schwehr at gmail.com
Mon Jul 11 08:11:59 PDT 2016
Even,
I think this looks good and a big win for a lot of use cases.
Comments related to the flags defined in gcore/gdal.h:
- If possible, use an enum rather than bare defines.
- Add comments to gdal.h explaining what the values are
- Should an unimplemented also have the _DATA flag set rather than _EMPTY?
A suggestion for this
<https://github.com/OSGeo/gdal/compare/trunk...rouault:sparse_datasets?expand=1#diff-66f7e256611c32cddc2745d78b4fe59bR3787>,
which looks brittle to me:
     if( nStatus != GDAL_DATA_COVERAGE_STATUS_EMPTY )
A helper function to check empty rather than a direct check will allow for
later or'ing the status with other flags.  Or you can & with the flag.  But
looking at it a second time, I think it might be more explicit if you did a
check against having data:
    if( nStatus & GDAL_DATA_COVERAGE_STATUS_DATA )
-kurt
On Sun, Jul 10, 2016 at 2:54 AM, Even Rouault <even.rouault at spatialys.com>
wrote:
> Le dimanche 10 juillet 2016 11:32:48, Andrew C Aitchison a écrit :
> > On Fri, 8 Jul 2016, Even Rouault wrote:
> > > The topic of sparse dataset management come back regularly, so I've
> > > decided to tackle it.
> > > Please find
> > > https://trac.osgeo.org/gdal/wiki/rfc63_sparse_datasets_improvements
> for
> > > review.
> > I know of several proprietary file formats where the data is tiled
> > with the index indicating (perhaps implicitly) where the tile has no
> > data.
> > A driver for such formats could have IReadBlock quickly return with
> > a code to indicate NoData, rather than filling in the image data.
> > As it stands that might mean extending CPLErr, but would
> > that be helpful to the main library ?
> That would have a significant impact on the whole code base, as well as
> application code, so I didn't really considered that option and prefered an
> auxiliary interface to be used by code aware and caring about special
> behaviour for sparse datasets.
> > Is this what is described by having the offset and byte count both zero ?
> Yes, in TIFF, you have 2 arrays, one that indicates at which offset in the
> file
> a given tile/strip is located, and the other one for the number of bytes of
> that tile/strip. GDAL uses offset = count = 0 as a convention for missing
> blocks.
> > I don't really understand how GDAL_DATA_COVERAGE_STATUS values combine
> > or
> * If the requested window contains has no missing blocks, it returns
> * If the requested window has only missing blocks, it returns
> * If the requested window is a mix of both, it returns
> GDAL_DATA_COVERAGE_STATUS_DATA | GDAL_DATA_COVERAGE_STATUS_EMPTY
> > when pdfDataPct is valid.
> It should be valid if the processing has not been stopped prematurely due
> to
> the nMaskFlagStop being triggered. For example if you have a dataset and
> you
> want a special processing (could be just an info "This dataset is sparse")
> as
> soon as it contains empty blocks, then you can query the whole dataset
> extent
> with nMaskFlagStop = GDAL_DATA_COVERAGE_STATUS_EMPTY. As soon as a missing
> block is found, the function will exit, and will thus be unable to
> determine
> the percentage of valid data.
> > In one of the formats above, the tile index has special values
> > for "no data" and and for "data exists and could be retrieved/purchased
> > if required". I'd consider mapping these to
> Clearly a missing block will cause GDAL_DATA_COVERAGE_STATUS_EMPTY to be
> set.
> > and GDAL_DATA_COVERAGE_STATUS_UNIMPLEMENTED. Does that make sense ?
> GDAL_DATA_COVERAGE_STATUS_UNIMPLEMENTED is aimed at being returned when a
> driver does not offer an implementation of the interface, and thus uses the
> default dumb implementation that returns
> I realize that I didn't really document yet the semantics of those flags.
> To be
> done.
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
http://schwehr.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160711/4af4b48e/attachment.html>
