[gdal-dev] GDAL raster processing library?
James Ramm
jamessramm at gmail.com
Tue Jul 12 07:39:34 PDT 2016
Hi Even,
The difference I see with pixel functions is that, as far as I understand,
the pixel function is applied per pixel, so there is no possibility of e.g.
the pixel buffer when have the function apply to 'blocks'.
I may be way off, but many of the algorithms we deal with require some kind
of neighbourhood search - a polygonise algorithm or flow direction
algorithm being good examples.
I dont think VRT pixel functions allow this?
So in that sense I'd see a VRT being 'just' another potential input data
source.
Perhaps VRT pixel functions could be expanded to also allow 'window'
functions?
A downside is it requires creating a VRT even when you only want to apply a
such a function to a single dataset. Small effort, but still a bit more
than throwing in any GDALDataset to be processed.
I see the overlap with raster algebra, although yes technically very
different.
On 12 July 2016 at 14:55, Even Rouault <even.rouault at spatialys.com> wrote:
> James,
> There's some intersection with Ari's proposal :
> https://trac.osgeo.org/gdal/wiki/rfc62_raster_algebra . At least
> regarding the
> overall purposes, since technically this is quite different.
> Actually what you propose is very close to the existing VRT pixel
> functions of
> derived bands. See "Using Derived Bands" in
> http://www.gdal.org/gdal_vrttut.html . In the last days, we've merged
> Antonio's work regarding a predefined set of pixel functions.
> Perhaps some extension to allow passing user parameters to the pixel func
> could be useful. It is possible to use pixel functions from Python as
> shown in
> https://github.com/OSGeo/gdal/blob/trunk/autotest/gcore/testnonboundtoswig.py#L303
> although this is a bit ugly as it uses ctypes and not SWIG. But should be
> possible through SWIG by introducing proper types similarly to what is done
> for the progress functions or error handler functions.
> Even
> Le mardi 12 juillet 2016 14:40:27, jramm a écrit :
> > I wonder if there is a use case/interest in a small library within GDAL
> to
> > facilitate generic raster processing.
> > My idea would be to have a user-extensible framework to run processing
> > functions on whole rasters, with a growing library of common-such
> functions
> > within GDAL.
> > Something along the lines of this:
> > typedef CPLErr (*GDALRasterProcessFn)(double *padfInArray, double
> > *padfOutArray,
> > int nWindowXSize, int nWindowYSize, void *pData, double
> > *pdfNoDataValue);
> > * \brief Definition of a raster processing function.
> > * A GDALRasterProcessFn accepts an array of data as input, applies custom
> > logic and writes the output to padfOutArray.
> > * Such a function can be passed to GDALRunRasterProcess to apply custom
> > processing to a GDALDataset in chunks and create
> > * a new GDALDataset.
> > * @param padfInArray The input array of data.
> > * @param padfOutArray The output array of data. On first call (via
> > GDALRunRasterProcess) this will be an empty, initialised array,
> > * which should be populated with the result of calculations on
> > padfInArray. In subsequent calls it will contain the result of the
> > * previous window.
> > * @param nWindowXSize the actual x size (width) of the read window.
> > * @param nWindowYSize the actual y size (height) of the read window. The
> > length of padfInArray == padfOutArray == nWindowXSize * nWindowYSize
> > * @param pData Process-specific data. This data is passed straight
> through
> > to the GDALRasterProcessFn and may contain e.g user defined parameters.
> > * The GDALRasterProcessFn definition would define the structure/type
> of
> > such data.
> > * @param pdfNoDataValue The no data value of the dataset
> > CPLErr GDALRunRasterProcess(GDALRasterProcessFn processFn, GDALDataset
> > *poSrcDataset,
> > GDALDataset *poDstDataset, void *pData, int
> > *pnWindowXSize,
> > int *pnWindowYSize, int *pnPixelBuffer);
> > * \brief Apply a raster processing function to each sub-window of a
> raster.
> > * The input raster dataset is read in chunks of nWindowXSize *
> nWindowYSize
> > and each chunk is passed to the processing
> > * function. The output array from the function is written to the
> > destination dataset.
> > * An optional 'pixel buffer' can be specified to allow overlaps between
> > successive windows. This is useful for
> > * some algorithms, e.g. blob extraction, watershed/stream flow analysis,
> > convolution etc.
> > * Process specific data can be passed (e.g. configuration parameters).
> This
> > data is simply passed straight through to the processing
> > * function on each call.
> > * @param processFn A GDALRasterProcessFn to apply to each sub window of
> the
> > raster.
> > * @param poSrcDataset The source raster dataset from which pixel values
> are
> > read
> > * @param poDstDataset The destination raster dataset to which pixel
> values
> > are written. Must support RasterIO in write mode.
> > * @param pData Process-specific data. This is passed straight through to
> > the GDALRasterProcessFn on each call.
> > * @param pnWindowXSize The desired width of each read window. If NULL it
> > defaults to the 'natural' block size of the raster
> > * @param pnWindowYSize The desired height of each read window. If NULL it
> > defaults to the 'natural' block size.
> > * @param pnPixelBuffer A pixel buffer to apply to the read window. The
> read
> > window is expanded by pnPixelBuffer pixels in all directions such that
> > * each window overlaps by pnPixelBuffer pixels. Ignored if NULL or 0
> > * @return a CPLErr enum indicating whether the function succesfully ran.
> > CPLErr GDALRunRasterProcesses(GDALRasterProcessFn *paProcessFn, int
> > nProcesses, GDALDataset *poSrcDataset,
> > GDALDataset *poDstDataset, void **paData, int
> > *pnWindowXSize,
> > * \brief Apply multiple raster processing functions to each sub-window
> of a
> > raster
> > * For each window, the functions defined by the paProcessFn array are
> > called in turn, with the array output of the previous function forming
> the
> > input * to the next function. This allows processing 'toolchains' to be
> > built without having to create intermediate datasets, which can be less
> > efficient in time and space.
> > * @param paProcessFn An array of GDALRasterProcessFn to apply to each sub
> > window of the raster
> > * @param nProcesses The size of paProcessFn
> are
> > read
> values
> > * @param paData an array of process-specific data objects of size
> > nProcesses. Each data object will be passed to the corresponding
> > GDALRasterProcessFn
> read
> > * each window overlaps by pnPixelBuffer pixels. If NULL, it is
> ignored.
> > So GDALRunRasterProcess would take care of I/O and looping through the
> > dataset in chunks, which can be configure by the user. Each chunk is
> > submitted to the processing function, which does 'stuff' and populates
> the
> > output array. GDALRunRasterProcess would write it to the output dataset
> > object.
> > An example of a processing function could be something like this:
> > typedef struct ReclassArgs {
> > int nReclassArgs;
> > double *padfMinBound;
> > double *padfMaxBound;
> > double *padfBinValue;
> > } ReclassArgs;
> > CPLErr Reclass(double *padfInArray, double *padfOutArray,
> > double *pdfNoDataValue)
> > ReclassArgs *poRargs = static_cast<ReclassArgs *>(pData);
> > double pixel;
> > for (int i = 0; i < nWindowXSize * nWindowYSize - 1; ++i){
> > pixel = padfInArray[i];
> > for (int k = 0; k < poRargs->nReclassArgs; ++k){
> > if ((pixel > poRargs->padfMinBound[k]) && (pixel <=
> > poRargs->padfMaxBound[k])){
> > padfOutArray[i] = poRargs->padfBinValue[k];
> > break;
> > return CE_None;
> > To use it you would:
> > // Open a source dataset
> > GDALDataset *poSrc = GDALOpen(...)
> > // Create some output dataset with same dimensions etc..
> > GDALDataset *poDst = ....
> > // Setup the reclass args
> > ReclassArgs *poRargs = ...
> > // Call the process
> > CPLErr retval = GDALRunRasterProcess(Reclass, poSrc, poDst, (void
> > *)poRargs, NULL, NULL, NULL);
> > GDAL could feature its own library of common functions...reclass,
> truncate,
> > blob extraction etc etc and a user of GDAL could write their own and have
> > GDAL process it.
> > It would be useful to expose enough to python via SWIG so that a
> > GDALRasterProcessFn could be defined in python - this would then allow
> > rapid development in python, but push the expensive work of looping over
> > dataset chunks to C++.
> > I dont know enough about SWIG yet to see whether this would be feasible.
> > However, even in C++, it allows the user to only think about their
> > algorithm and leave the boilerplate to GDAL.
> > I imagine all this being implemented in a 'sub library', something like
> > gdpl.h (geospatial/gdal dataset processing library), but sitting in the
> > GDAL source tree (then I can happily expose all the useful GDAL goodness
> > without being worried about users having to include gdal headers etc, and
> > avoid any work in having to abstract it away)
> > This is a first stab at defining something like this and is probably not
> > yet comprehensive enough.
> > Any thoughts?
> > View this message in context:
> http://osgeo-org.1560.x6.nabble.com/GDAL-raster-processing-library-tp52759
> > 48.html Sent from the GDAL - Dev mailing list archive at Nabble.com.
> > gdal-dev mailing list
> > gdal-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160712/39ec585f/attachment-0001.html>
