[gdal-dev] Fwd: Problem with gdal.Rasterize utility : argument GDALDatasetShadow in wrapper_GDALRasterizeDestName
Even Rouault even.rouault at spatialys.com
Thu Jul 14 13:35:06 PDT 2016
Le jeudi 14 juillet 2016 21:13:24, François ALLAIN a écrit :
> Hello,
> I am trying to convert a gdal_rasterize command to a gdal.Rasterize call
> with the Python bindings
> (Python 2.7.9 64bits, GDAL 2.1.0 compiled with libproj0 libgeos-dev on
> Debian 8.3).
> The  gdal_rasterize command works perfectly  :
> gdal_rasterize -i -b 4 -burn 0 my.geojson my.tif
> With the information available on the web :
> http://erouault.blogspot.ie/2015/10/gdal-and-ogr-utilities-as-library.html
> https://trac.osgeo.org/gdal/wiki/rfc59.1_utilities_as_a_library
> http://gis.stackexchange.com/questions/77139/why-do-shapefiles-and-geojson-
> behave-differently-in-gdal-python
> I've tried this kind of script :
> import os
> import sys
> from osgeo import gdal, ogr, osr
> geojson_filename = "my.geojson"
> driver = ogr.GetDriverByName("GeoJSON")
> vector_ds = driver.Open(geojson_filename, gdal.GA_ReadOnly)
> geotiff_filename = "my.tif"
> ds = gdal.Open(geotiff_filename, gdal.GA_Update)
> ret = gdal.Rasterize(ds, vector_ds,
>             bands = [4],
>             inverse = True,
>             burnValues = [0])
> if ret != 1:
>     print 'fail'
> else:
>     print 'success'
> but I kept getting this error :
> Traceback (most recent call last):
>   File "test.py", line 62, in <module>
>     ret = gdal.Rasterize(ds, vector_ds, bands = [4], inverse = True,
> burnValues = [0])
>   File "/usr/local/lib/python2.7/dist-packages/osgeo/gdal.py", line 1046,
> in Rasterize
>     return wrapper_GDALRasterizeDestName(destNameOrDestDS, srcDS, opts,
> callback, callback_data)
> TypeError: in method 'wrapper_GDALRasterizeDestName', argument 2 of type
> 'GDALDatasetShadow *'
François,
I presume the issue is with how the vector_ds has been opened.
gdal.Rasterize() expects all datasets, raster or vector, to be of type
GDALDatasetShadow. When you open with ogr.Open(), this is not the case.
Try:
vector_ds  = gdal.OpenEx( geojson_filename, gdal.OF_VECTOR )
Even
http://www.spatialys.com
