[gdal-dev] SPOT-7 and Worldview 3
Shawn Gong SGONG at mdacorporation.com
Fri Jul 15 08:29:19 PDT 2016
Hi all,
I have downloaded and built gdal 2.1.1
Ran some tests on SPOT-7 and Worldview 3
SPOT-7 tiled dimap: the DIM_SPOT7_*.xml file was loaded fine. But the georeferencing was wrong.  The xml seems to indicate ITRF2005 (epsg 4896) but it has no projection information in gdal.  The individual geotiffs didn't seem to agree with the xml either
Worldview 3: the TIL file was loaded fine. UTM georeferencing looks good.
Thanks,
Shawn
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160715/89b4e5d6/attachment.html>
