[gdal-dev] Memory increase in postgis raster driver
jramm
jamessramm at gmail.com
Wed Jul 20 03:12:59 PDT 2016
I am seeing a continuous, linear memory increase when reading sequential
windows of a large postgis dataset. This is the same regardless of my
GDAL_CACHEMAX settings
If I run he same code on an equivalent GTiff dataset, I do not see the same
increase in memory.
I can see that the postgis dataset RasterIO implementation calls CacheTile
for each tile it reads, which I think uses the GDAL caching mechanism - is
it possible that, since each tile will be *new* (due to the sequential read
over the dataset), it is somehow cached outside of the gdal cache/ignoring
the CACHEMAX setting?
I'm just stabbing in the dark here as I can't really find a reason for it
yet
View this message in context: http://osgeo-org.1560.x6.nabble.com/Memory-increase-in-postgis-raster-driver-tp5277284.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
