[gdal-dev] C++ API for WCS: GetCapabilities and GDALOpen()
Odd Ragnar Lydersen
Odd-Ragnar.Lydersen at powel.no
Thu Jul 21 06:36:12 PDT 2016
This is probably a stupid question, but I'm wondering if the WCS driver is missing something.
1) I have used the WFS driver, and the description xml file, which caches the GetCapabilitis result, so that I can get info from that file later.
2) The corresponding description xml file for the WCS driver does not support any calls to GetCapabilities.
I'm required to give <CoverageName>SomeCoverage</CoverageName>, before I really know the name of the coverage.
I can't give the GetCapabilities request in the url either. That results in an error from GDAL.
If I'm to open a new WCS in my program and list all available coverages, then I need to call GetCapabilities first.
Does GDAL fetch this for me in some way, or do I have to parse the result from GetFeatureInfo in a separate routine?
Shouldn't the first call to GDALOpen() get the capabilitis for a given WCS, like it does for WFS?
PS! I'm using GDAL 1.11.1
>Odd-Ragnar<
