[gdal-dev] gdal_edit with ECW, parameter woes, documentation is probematic
Mark Johnson
mj10777 at googlemail.com
Tue Jul 26 07:18:21 PDT 2016
Yes, that looks good.
But also adapting the pages that use -co NAME=VALUE
- such as http://www.gdal.org/gdal_translate.html
<dt><b>-co</b> <em>"NAME=VALUE"</em>:</dt>
<dd>Passes a creation option to the output format driver. Multiple
<b>-co</b> options may be listed. See format specific documentation for
legal creation options for each format. </dd>
<b>-co</b> options may be listed. See <a class="el"
href="formats_list.html" title=""GDAL Raster Formats">format specific
documentation for legal creation options for each format</a>. </dd>
would also be good, leading the searcher swiftly to the needed page where
they can select their needed format to look up the possible parameter
combinations.
Mark
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160726/dcd5cb53/attachment.html>
