[gdal-dev] gdalwarp -rpc with RPC_DEM default behavior not as described
Even Rouault
even.rouault at spatialys.com
Tue Jul 26 09:54:06 PDT 2016
Patrick,
Thanks for the report. It was indeed not working as documented. Fixed per
https://trac.osgeo.org/gdal/ticket/6608
Even
> Hi all,
> We've been making some orthos with gdalwarp (gdal version 2.1.1) and
> encountering resampling errors in the output (gittery output in the lines
> in certain spots). Long story short, explicitly setting the "-et" option
> to "0" fixed it, but the docs for gdalwarp say the following (under the -et
> flag description):
> "starting with GDAL 2.1, the RPC_DEM warping option is specified, in which
> case, an exact transformer, i.e. err_threshold=0, will be used"
> Here's an example of the call we're making where we see the artifacts:
> gdalwarp -t_srs EPSG:3857 -rpc -to RPC_DEM=dem.tif in.tif out.tif
> and this guy fixes it:
> gdalwarp -et 0 -t_srs EPSG:3857 -rpc -to RPC_DEM=dem.tif in.tif out.tif
> I'm guessing the flag is not actually being set, but if anyone can point me
> to the code where this default is supposed to be set when the dem is
> specified, I might be able to provide a fix or figure out that I'm doing it
> wrong! I didn't have much luck searching through the github archive.
> Thanks!
> -Patrick
http://www.spatialys.com
