[gdal-dev] gdal_translate with -projwin possible bug
Rutger kassies at gmail.com
Thu Jul 28 23:22:17 PDT 2016
Thanks Even,
There is probably, like Jukka mentioned, a use case for both ways, but i
personally prefer your fix. If i want warp/shift functionality i use
gdalwarp anyway, and then you know you have to be careful about pixel
alignment etc.
Even Rouault-2 wrote
> I've pushed a fix in line with my previous email:
> https://trac.osgeo.org/gdal/ticket/6610
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> gdal-dev mailing list
> gdal-dev at .osgeo
View this message in context: http://osgeo-org.1560.x6.nabble.com/gdal-dev-gdal-translate-with-projwin-possible-bug-tp5278296p5278651.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
