[gdal-dev] Questions on working with HYCOM data in netcdf format
Stephen Woodbridge
woodbri at swoodbridge.com
Fri Jun 3 18:22:06 PDT 2016
Hi All,
I want to convert some HYCOM data into GTiff format and I'm a little
lost on how to get started, whether I can do what I need just using a
vrt or if I'm going to have to write code to process the data.
To start with I have placed gdalinfo on one file here:
http://imaptools.com:8080/dl/hycom-gdalinfo.txt
The data comes from http://hycom.org/dataserver/glb-analysis
and I will need to be using GLBa0.08 dataset.
I have two use cases:
1) The simple one is to extract say Band 1 into a georeferenced GTiff
and apply color to using color ranges without loosing the NODATA. I
think I can do later using .vrt, correct?
I'm not sure how to deal with the georeferencing, because the download
site says: "Native hycom .[ab] data converted to NetCDF on native
Mercator-curvilinear HYCOM horizontal grid" but that does not seem in
sync with the Metadata in the file.
2) The more complicated case is that there are two files:
a) eastward_sea_water_velocity (aka: u, u-velocity)
b) northward_sea_water_velocity (aka: v, v-velocity)
that I would like to use to create a grid of vectors with arrowheads
using u and v to define the vector and where the color of the vector is
related to the magnitude of its length. Ultimately this data will get
rendered via mapserver so I'm wondering if I can do this via a GTiff or
if I will have to resort to creating a massive point shapefile with
attributes of angle and magnitude and use a symbol. It seems like it
would be best if I can keep the data as a GTiff and then sample the
points and render the vectors on the fly for when you zoom in/out.
Interesting data and I'm really pleased to see gdal can access it! Kudos
on that.
Any guidance would be greatly appreciated.
Thanks,
-Steve
This email has been checked for viruses by Avast antivirus software.
https://www.avast.com/antivirus
