[gdal-dev] Fwd: How to reuse memory pointer of GDAL Memory driver
Pol Monsó Purtí
lluna.nova at gmail.com
Mon Jun 6 01:45:47 PDT 2016
THanks Mateusz,
You're right. I'm trying it as we speak.
In my case I have a std::vector<GByte*> of the 3 bands, where the GByte*
are allocated in the heap with new GByte[width*height]. I guess that won't
work because the three bands have to be one single memory chunk, am I
right? I guess the only solution is to switch to single band float and
merge rgb to float. I'd prefer not having to refactor the rest of the code.
Is it possible to have a different address for each band?
All this is to support jpg as output. All the operations are done in my
GByte array and it's only at the end that I create the dataset and image.
At the moment I create a Tiff and finally createcopy to jpg.
On Fri, Jun 3, 2016 at 9:10 PM, Mateusz Loskot <mateusz at loskot.net> wrote:
> On 3 June 2016 at 20:45, Pol Monsó Purtí <lluna.nova at gmail.com> wrote:
> > I've seen this mysterious article http://www.gdal.org/frmt_mem.html
> which
> > references the `DATAPOINTER` option. I've seen another reference
> > [here](
> https://lists.osgeo.org/pipermail/gdal-dev/2006-November/010583.html)
> > which does
> sprintf(filename,"MEM:::DATAPOINTER=%d,PIXELS=%d,LINES=%d,BANDS=1,DATATYPE=%d,PIXELOFFSET=0,LINEOFFSET=0,BANDOFFSET=0",datpt,pixels,lines,datatype);
> > dataset = GDALOpen(filename,GA_Update);
> > How would this translate to c++?
> The line above is valid C++, isn't it.
> If you followed to Frank's answer [1], you'd see it slightly corrected
> but the technique remains the same.
> [1] https://lists.osgeo.org/pipermail/gdal-dev/2006-November/010603.html
> Best regards,
> Mateusz Loskot, http://mateusz.loskot.net
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160606/0a71eaff/attachment.html>
