[gdal-dev] Questions on working with HYCOM data in netcdf format
Stephen Woodbridge woodbri at swoodbridge.com
Mon Jun 6 11:29:05 PDT 2016
On 6/6/2016 1:25 PM, Kurt Schwehr wrote:
> +gdal-dev
> Some hackish test code I had laying around from last year...
> https://gist.github.com/schwehr/01f6604afc7757ea0a676f0eb28be582
Thank you! I have it running, so next I'll play with the code.
> You might also be able to just write 80 layers of u-v, pick out pairs
> for each depth layer and have the rendering system do the
> conversion(s).  You could use whatever you want once you have a
> geotiff.  In this screenshot, I made an 80-layer geotiff of u and v
> alternating layers and uploaded that to Earth Engine.  It's been a long
> time since I heavily used mapserver, but you could probably do the same
> there.
> https://www.flickr.com/photos/schwehr/26895009754/
Very cool picture!
This really helps to get me started.
Thanks,
   -Steve
> On Mon, Jun 6, 2016 at 7:51 AM, Stephen Woodbridge
> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>> wrote:
>     On 6/5/2016 2:04 PM, Kurt Schwehr wrote:
>         Stephen,
>         Take a look at these two discussions for starters on working
>         with hycom:
>         http://gis.stackexchange.com/questions/167155/how-can-i-make-geotiffs-of-individual-depth-layers-in-the-hycom-ocean-circulatio
>     Hi Kurt,
>     In the link above you mention:
>         I've got some code written the does things like calculate the speed
>         inm/s from the UV and creates a geotiff, etc
>     Can you share this code, it sounds like exactly what I need for the
>     current vectors? And I'm interested in figuring out how to
>     read/write and work with the netcdf files.
>     I think for now I'll work with the "u" datasets as they seem that
>     they will be much easier place to start.
>     Thanks,
>       -Steve
>         http://gis.stackexchange.com/questions/170882/how-can-a-make-a-netcdf-with-subgroups-smaller
>         You should start with the regular grids.  e.g.
>         ftp://ftp.hycom.org/datasets/GLBu0.08/expt_91.1/data/hindcasts/2015/hycom_glb_911_2015093000_t000_uv3z.nc
>         Make an 80 layer geotiff from the u/v and then use mapserver as Even
>         suggested.
>         -kurt
>         On Sat, Jun 4, 2016 at 6:29 AM, Even Rouault
>         <even.rouault at spatialys.com <mailto:even.rouault at spatialys.com>
>         <mailto:even.rouault at spatialys.com>>> wrote:
>             Hi,
>             > I want to convert some HYCOM data into GTiff format and
>         I'm a little
>             > lost on how to get started, whether I can do what I need
>         just using a
>             > vrt or if I'm going to have to write code to process the data.
>             > To start with I have placed gdalinfo on one file here:
>             > http://imaptools.com:8080/dl/hycom-gdalinfo.txt
>             > The data comes from http://hycom.org/dataserver/glb-analysis
>             > and I will need to be using GLBa0.08 dataset.
>             > I have two use cases:
>             > 1) The simple one is to extract say Band 1 into a
>         georeferenced GTiff
>             > and apply color to using color ranges without loosing the
>         NODATA. I
>             > think I can do later using .vrt, correct?
>             gdaldem color-relief can output to a VRT, but given that
>         this netCDF
>             file is
>             georeferenced through a geolocation array, you'll likely
>         have first
>             to run
>             gdalwarp -geoloc to have something useful at the end.
>             > I'm not sure how to deal with the georeferencing, because
>         the download
>             > site says: "Native hycom .[ab] data converted to NetCDF on
>         native
>             > Mercator-curvilinear HYCOM horizontal grid" but that does
>         not seem in
>             > sync with the Metadata in the file.
>             > 2) The more complicated case is that there are two files:
>             >     a)  eastward_sea_water_velocity (aka: u, u-velocity)
>             >     b)  northward_sea_water_velocity (aka: v, v-velocity)
>             > that I would like to use to create a grid of vectors with
>         arrowheads
>             > using u and v to define the vector and where the color of
>         the vector is
>             > related to the magnitude of its length. Ultimately this
>         data will get
>             > rendered via mapserver so I'm wondering if I can do this
>         via a GTiff or
>             > if I will have to resort to creating a massive point
>         shapefile with
>             > attributes of angle and magnitude and use a symbol. It
>         seems like it
>             > would be best if I can keep the data as a GTiff and then
>         sample the
>             > points and render the vectors on the fly for when you zoom
>         in/out.
>             See
>             http://mapserver.org/input/vector/vector_field.html
>             You don't need to create a vector file.
>             You'll have to preprocess your file to get the u and v bands
>         in the same
>             raster.
>             Even
>             Spatialys - Geospatial professional services
>             http://www.spatialys.com
>             _______________________________________________
>             gdal-dev mailing list
>             gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
>         <mailto:gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>>
>             http://lists.osgeo.org/mailman/listinfo/gdal-dev
>         http://schwehr.org
>     This email has been checked for viruses by Avast antivirus software.
>     https://www.avast.com/antivirus
> http://schwehr.org
