[gdal-dev] R: Problem using ogrlineref
Dmitry Baryshnikov
bishop.dev at gmail.com
Tue Jun 7 09:25:50 PDT 2016
Hi Nicola,
The first and last segments usually have beg and end fields value not a
multiple of 1000.
I.e. begin = 576 m, end 1000 m or begin 76200 m, end 76234 m
This is ok, and ogrlineref correctly woks with this case.
I think, that you can try to play with your data without equal parts
sizes. But ogrlineref need - beg (double), end(double) and scale
(double) fields.
Scale - is spatial length of you part divided on linear lenght.
I.e. scale = part.get_Length() / (end - beg)
Best regards,
Dmitry
07.06.2016 18:25, Nicola Baraldo (ICONSULTING) пишет:
> Hi Dmitry,
> thank you for you response. There is a way to do the step 2 using GDAL?
> Moreover, if the path lengths are not multiple of the split size (e.g.
> 1000m), how the last segment is handled?
> Best regards,
> Nicola
> *Da:*gdal-dev [mailto:gdal-dev-bounces at lists.osgeo.org] *Per conto di
> *Dmitry Baryshnikov
> *Inviato:* martedì 7 giugno 2016 16:16
> *A:* gdal-dev at lists.osgeo.org
> *Oggetto:* Re: [gdal-dev] Problem using ogrlineref
> Hi Nicola,
> The idea of ogrlineref was follow:
> 1. You have layer with some lines and some reper points with known
> linear coordinates
> 2. The reper points divide lines on equal parts (e.i. 1000 m) - this
> is important that parts should be equal
> 3. The result file will have special structure (required fields: beg,
> end, scale, and some optional)
> 4. During referencing ogrlineref make attribute query and get needed
> part based on beg and end fields (which is rather fast), and than calc
> point position inside this part.
> In your case, the simple way is to extract begin and end point of your
> lines and make them reper points. After that all steps are usual.
> There is no sense to move other fields into the parts file from your
> original datasource. But you can use -lf option to store some value
> and use it in future for join with your original data.
> Best regards,
> Dmitry
> 07.06.2016 15:19, Nicola Baraldo (ICONSULTING) пишет:
> Hi guys,
> I am trying to split some routes into segments of the same length
> (dynamic segmentation) using ogrlineref command.
> My data is stored in a shapefile containing a set of paths, for
> each path I know the length in meters.
> I have tried ogrlineref with –create, –get_coord and - get_subline.
> For the first option I don’t have a reper datasource to provide
> because I don’t have mile-stones, are they really necessaries?
> The second and third options give me the following error for each
> path contained in the input shapefile; with –get_coord I have
> tried both options “–m 0” and “–m 1000”, with –get_subline I have
> tried “-mb 0 -me 1” options.
> Can someone help me using this command? Is there a better way to
> perform dynamic segmentation using GDAL?
> Moreover my shapefile contains also a lot of other fields, there
> is a way to keep these information also in the output file?
> Thanks,
> Nicola
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160607/1ce663d2/attachment.html>
