[gdal-dev] Is option --utility_version documented?
Jukka Rahkonen jukka.rahkonen at maanmittauslaitos.fi
Wed Jun 15 03:40:57 PDT 2016
I noticed an utility program option --utility_version from
https://trac.osgeo.org/gdal/changeset/34340.
Am I right that this option does not appear in any user documentation? If
not I would like to add it into http://gdal.org/ogr_utilities.html and
http://gdal.org/gdal_utilities.html
Option returns for example
"gdalinfo was compiled against GDAL 2.1.0dev and is running against GDAL
2.1.0dev"
Is it possible the compile and runtime versions are different? What can lead
to such situation, and what trouble it makes?
-Jukka Rahkonen-
