[gdal-dev] SetSpatialFilter and Spatial Index
Tomer tomerlieber at gmail.com
Thu Jun 16 13:04:39 PDT 2016
Or maybe the question need to be if I set geometry as spatial filter using
the "SetSpatialFilter" function and then I use the function "GetNextFeature"
on a layer with spatial index, for instance shp file with qix. It will
consider the spatial index when fetch the next available feature from this
layer?
Thanks again,
Tomer
View this message in context: http://osgeo-org.1560.x6.nabble.com/SetSpatialFilter-and-Spatial-Index-tp5271637p5272096.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
