[gdal-dev] Not able to build GDAL on RHEL_5 64 bit?
sablok
sablok at amazon.com
Fri Jun 24 10:13:56 PDT 2016
The options --without-sqlite doesn't work :( and I am the point of
frustration now, even though I have all the libraries for sqlite3 in my
build path all the sqlite2 so's even tried changing the LD_LIBRARY_PATH
environment variable nothing works.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Not-able-to-build-GDAL-on-RHEL-5-64-bit-tp5272915p5273253.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
