[gdal-dev] Next maintenance releases
Even Rouault
even.rouault at spatialys.com
Fri Jun 24 14:09:50 PDT 2016
Le vendredi 24 juin 2016 22:55:03, Blumentrath, Stefan a écrit :
> Hi again,
> And thanks for your swift reply.
> After removing the dust from my MSVC 2010 express, I managed to build the
> trunk version of GDAL on Win 7 Pro (happy that I wrote down the build
> procedure here: https://trac.osgeo.org/gdal/wiki/SOSI).
> The Windows build went fine too and I can now open the SOSI file with a
> curved geometry, which crashed before.
> However, for completeness: I got two SOSI related warnings:
> C:\gdal-svn-trunk-2016.06.r\ogrsf_frmts\sosi\ogrsosilayer.cpp(332) :
> warning C4244: 'argument' : conversion from 'int' to 'float', possible
> loss of data
> C:\gdal-svn-trunk-2016.06.r\ogrsf_frmts\sosi\ogrsosidatatypes.cpp(58) :
> warning C4244: 'return' : conversion from 'double' to 'float', possible
> loss of data
Should be fixed by r34419
Whole driver now backported to 2.1
http://www.spatialys.com
