[gdal-dev] wrapper_GDALWarpDestName returned NULL without setting an error - from Python gdalwarp interface
Even Rouault
even.rouault at spatialys.com
Mon Jun 27 04:42:45 PDT 2016
Robin,
> Am I doing something wrong here in how I set the parameters for the
> gdal.Warp call?
Yes. All "librarified" command line utilities have been designed with the
gdal.XXXX(dest, source, ....) convention (similarly to Dataset.CreateCopy()
for example), so if you switch your 2 first arguments that should work.
Even
http://www.spatialys.com
