[gdal-dev] Google Summer of Code
Dmitry Baryshnikov
bishop.dev at gmail.com
Sat Mar 12 09:17:00 PST 2016
Hi Tanuj,
I wrote a big letter to the list. There is some answers there. Also I
add comments below.
Best regards,
Dmitry
12.03.2016 10:36, Tanuj Kumar пишет:
> Sorry for replying so late, got caught up in an exam :)
> I replaced libpng folder of gdal (frmts/png/libpng) with libpng
> 1.6.21. And then used ./configure and make install on this test
> version of gdal, which installed successfully. I used gdalinfo on a
> png file provided with the libpng 1.6.21 source, to check if it was
> OK, and it successfully gave the png file details.
> Is that enough to check the build on the computer?
No, the autotests must be passed.
> I have also tested the gdal library with libpng 1.6.21 on Travis, and
> the build succeeded.
> https://travis-ci.org/Raeburn1687/gdal/builds/115487530
> Would all that be enough to check whether the update was succesful?
I expected that travis from main gdal repo checked your PR.
> PS - Although I have copied the files from libpng 1.6.21 source to the
> gdal libpng folder, how would I know if any of those files are not
> required for gdal?
You need to see the previous version. Some files not needed (i.e.
configures and so on, which already comes from gdal, but legal notice
must be present (license, autors, etc.) ). Don't hesitate to ask in list.
> Thank you
> Tanuj
> On Thu, Mar 10, 2016 at 2:07 PM, Dmitry Baryshnikov
> <bishop.dev at gmail.com <mailto:bishop.dev at gmail.com>> wrote:
> Hi Tanuj,
> 09.03.2016 13:17, Tanuj Kumar пишет:
>> Yes, I have looked at the ideas list, and I am currently reading
>> up on idea no. 16, which is, implementing support for the
>> proposed standard for incrementally parseable GeoJSON data.
>> Also, I was thinking that maybe I could work on ticket no 6294,
>> https://trac.osgeo.org/gdal/ticket/6294
>> after I've studied about the GSoC idea, which is not really a
>> bug, but an enhancement. But if there are any other tickets that
>> you or anyone else would like to recommend me to work on, I'd
>> love to see them too!
> I think this rather arguing ticket as the bool is not exist in
> plain C, and duplication functions seems to me not good idea.
> I think this ticket https://trac.osgeo.org/gdal/ticket/6185 is
> good for: 1. building GDAL, 2. Testing via TraviC on GitHub. By
> the way the libpng version is 1.6.21 or maybe higher.
> Anyhow, you have to try to build gdal and test it with autotests
> from appropriate folder.
>> Now, about the GSoC idea, do I need to know JSON( or GeoJSON, for
>> that matter) to work on it? I only ask because the idea lists
>> C/C++ as the required skills, but I feel that maybe this work
>> would involve knowing JSON too...
> Yes, certainly. But JSON are very simple. Also GeoJSON spec. can
> be found here http://geojson.org/Thanks and regards,
>> Tanuj
>> On Wed, Mar 9, 2016 at 2:58 PM, Dmitry Baryshnikov
>> Hi, Tanuj
>> I'll look for opened tickets for you, or maybe others can
>> recommend some for you.
>> By the way, do you see the idea list
>> (https://trac.osgeo.org/gdal/wiki/SummerOfCode#a2016IdeasList)?
>> The ideas are not ranked yet - the numbers in the list - are
>> only in order.
>> This is a task for us to rank the ideas.
>> But, have you some preferable idea (or ideas) for GSoC from
>> this list or maybe you have got own?
>> Best regards,
>> Dmitry
>> 04.03.2016 16:11, Tanuj Kumar пишет:
>>> Hello,
>>> I am interested in applying for GSoC this year. Currently, I
>>> am reading up on the GDAL Summer of Code ideas list. I know
>>> C++ and C, and I have some experience on working on linux.
>>> Could the mentors please recommend a bug for me to work on,
>>> I'd really love to start off as soon as possible!
>>> Thank you,
>>> Tanuj Kumar
>>> Birla institute of Technology and Science
>>> Pilani, Rajasthan,
>>> India
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> Best regards,
> Dmitry
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160312/590c8ed9/attachment-0001.html>
