[gdal-dev] GSOC 2016
Dmitry Baryshnikov bishop.dev at gmail.com
Sun Mar 13 07:13:27 PDT 2016
Hi Sarthak,
1. The GDAL have 2 postgis drivers (raster and vector).
2. You need to add some information to the doxygen comment of
GetConnectionInfo method about new functionality.
3. Do you look at psql behaviour? It seems to me the ticket author means
to get the database name not only from environment variable, but also
from the current logged user name.
4. There is a logic error: You form connection string based on
parameters (papszParams) here -
https://github.com/sarthak-0415/gdal/blob/trunk/gdal/frmts/postgisraster/postgisrasterdataset.cpp#L2502
, but change the
papszParams below (i.e.
https://github.com/sarthak-0415/gdal/blob/trunk/gdal/frmts/postgisraster/postgisrasterdataset.cpp#L2605).
Also changed papszParams never used and only freed here -
https://github.com/sarthak-0415/gdal/blob/trunk/gdal/frmts/postgisraster/postgisrasterdataset.cpp#L2735.
Best regards,
     Dmitry
13.03.2016 00:10, sarthak agarwal пишет:
> Thank you for your reply Dmitry,
> Yesterday I was working on ticket 6294
> <https://trac.osgeo.org/gdal/ticket/6294> but since you said it was
> controversial I started to look around at ticket 6316
> <https://trac.osgeo.org/gdal/ticket/6316>,
> I figured out that we have to add a |else| statement after this code
> <https://github.com/sarthak-0415/gdal/blob/trunk/gdal/frmts/postgisraster/postgisrasterdataset.cpp>
> to give a default value to the |ppszDbname| in case user dosen’t
> provide any database name by default.
> And I suggest this small enhancement
> <https://github.com/OSGeo/gdal/commit/e7b2e9e9cd946d257cae5dfd196b4786cc2c0e94>
> to the code.
> Although I am not sure of this line
> <https://github.com/sarthak-0415/gdal/blob/trunk/gdal/frmts/postgisraster/postgisrasterdataset.cpp#L2642>
> where I want to copy the |userName| into |dbName|.
> This is a small fix and I wanted to discuss further on it.
> I have succesfully build the code on travis
> <https://travis-ci.org/sarthak-0415/gdal/builds/115574203>, please
> check it once.
> I have some doubts regarding some variables and functions for which I
> am still reading the code.
> I will get back to you if I have some more doubts.
> Regards,
> Sarthak
> On Sat, Mar 12, 2016 at 10:42 PM, Dmitry Baryshnikov
> <bishop.dev at gmail.com <mailto:bishop.dev at gmail.com>> wrote:
>     Hello GSoC students!
>     Many of you wrote to different lists and directly for me. I tried
>     to systematize your questions.
>     1. First of all each student need to subscribe to
>     soc at lists.osgeo.org <mailto:soc at lists.osgeo.org> (the themes
>     connected with organizing moments) and gdal-dev at lists.osgeo.org
>     <mailto:gdal-dev at lists.osgeo.org> (the themes about ideas,
>     tickets, coding and community). Please don't flood both lists the
>     same letters.
>     2. Next - I dig the GDAL tracker and found some tickets worth to
>     be fixed. This work help you to understand the project structure
>     and how it works (building, testing and so on) and help project to
>     became better.
>     The expected result is applied pool request in GDAL main
>     repository at github (https://github.com/OSGeo/gdal).
>     By the way, after pool request to this repository, the provided
>     fixes are tested via TravisC and over test utilities.
>     Before making pool request please test it yourself (ubuntu and
>     windows is enough, virtualbox or preferable virtualization soft
>     may help here).
>     Here is the tickets I think is good for you (it's welcome if
>     community fix this list - maybe some tickets need to be excluded
>     or some included):
>     - https://trac.osgeo.org/gdal/ticket/2773
>     - https://trac.osgeo.org/gdal/ticket/5035 - Alex
>     - https://trac.osgeo.org/gdal/ticket/5347
>     - https://trac.osgeo.org/gdal/ticket/5592
>     - https://trac.osgeo.org/gdal/ticket/5681
>     - https://trac.osgeo.org/gdal/ticket/5705
>     - https://trac.osgeo.org/gdal/ticket/6185 - Tanuj
>     - https://trac.osgeo.org/gdal/ticket/6222
>     - https://trac.osgeo.org/gdal/ticket/6246
>     - https://trac.osgeo.org/gdal/ticket/6304
>     - https://trac.osgeo.org/gdal/ticket/6316
>     - https://trac.osgeo.org/gdal/ticket/6385
>     I checked tickets already get by students. It's good to discuss
>     with community how you plan to fix the tickets before start
>     coding. Also, choose tickets carefully, we need students with good
>     skills, so the ticket should show your potential. Some of you
>     already choose another tickets, and this is normal too, but they
>     need to be discussed too. For example the ticket
>     https://trac.osgeo.org/gdal/ticket/6294 is rather controversial.
>     3. We need to see which ideas each of student choose, and what is
>     a plan how to release them. You need some discussion with the
>     community what is best way or some directions to do it. This is
>     not spoil of the time as your ideas come as background for your
>     project announces.
>     It'll be nice have more details for some ideas from list
>     https://trac.osgeo.org/gdal/wiki/SummerOfCode. The ideas #7,8,9
>     are very briefly.
>     Best regards,
>         Dmitry
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160313/3efc291f/attachment-0001.html>
