[gdal-dev] GSOC 2016
sarthak agarwal
sarthak0415 at gmail.com
Sun Mar 13 14:36:05 PDT 2016
On Sun, Mar 13, 2016 at 11:07 PM, Even Rouault <even.rouault at spatialys.com>
wrote:
On Sunday 13 March 2016 17:13:27 Dmitry Baryshnikov wrote:
> > Hi Sarthak,
> > 1. The GDAL have 2 postgis drivers (raster and vector).
RIght now I am working on raster part, I still have to figure out which
part of the code takes care of vector postgis driver.
> 2. You need to add some information to the doxygen comment of
> GetConnectionInfo method about new functionality.
I made changes in the comments, I guess doxygen reads comments in between
the lines of the code. If still I have to make some changes, please tell me.
> 3. Do you look at psql behaviour? It seems to me the ticket author means
> > to get the database name not only from environment variable, but also
> > from the current logged user name.
> We should be as tolerant as the OGR PG driver is. ie not constraint the
> user
> to specify more than what PQconnectdb() requires (ie it can be potentially
> empty)
> I have made the changes to make DBname to NULL if we do not have any
database name or username.
> > 4. There is a logic error: You form connection string based on
> > parameters (papszParams) here -
> https://github.com/sarthak-0415/gdal/blob/trunk/gdal/frmts/postgisraster/pos
> > tgisrasterdataset.cpp#L2502 , but change the
> > papszParams below (i.e.
> > tgisrasterdataset.cpp#L2605). Also changed papszParams never used and
> only
> > freed here -
> > tgisrasterdataset.cpp#L2735.
I fixed that logical error, and Now it reads the username twice (once to
init the dbname and second for the connection)
you can find those changes here
<https://github.com/OSGeo/gdal/compare/trunk...sarthak-0415:trunk#diff-31df0e62d00ca09f9f11ad2f29e94b540>
and travis <https://travis-ci.org/sarthak-0415/gdal/builds/115730596> for
the builds.
Regards,
Sarthak
> > Best regards,
> > Dmitry
> > 13.03.2016 00:10, sarthak agarwal пишет:
> > > Thank you for your reply Dmitry,
> > > Yesterday I was working on ticket 6294
> > > <https://trac.osgeo.org/gdal/ticket/6294> but since you said it was
> > > controversial I started to look around at ticket 6316
> > > <https://trac.osgeo.org/gdal/ticket/6316>,
> > > I figured out that we have to add a |else| statement after this code
> > > postgisrasterdataset.cpp> to give a default value to the |ppszDbname|
> in
> > > case user dosen’t
> > > provide any database name by default.
> > > And I suggest this small enhancement
> https://github.com/OSGeo/gdal/commit/e7b2e9e9cd946d257cae5dfd196b4786cc2c
> > > 0e94> to the code.
> > > Although I am not sure of this line
> > > postgisrasterdataset.cpp#L2642> where I want to copy the |userName|
> into
> > > |dbName|.
> > > This is a small fix and I wanted to discuss further on it.
> > > I have succesfully build the code on travis
> > > <https://travis-ci.org/sarthak-0415/gdal/builds/115574203>, please
> > > check it once.
> > > I have some doubts regarding some variables and functions for which I
> > > am still reading the code.
> > > I will get back to you if I have some more doubts.
> > > Regards,
> > > Sarthak
> > > On Sat, Mar 12, 2016 at 10:42 PM, Dmitry Baryshnikov
> > > <bishop.dev at gmail.com <mailto:bishop.dev at gmail.com>> wrote:
> > > Hello GSoC students!
> > > Many of you wrote to different lists and directly for me. I tried
> > > to systematize your questions.
> > > 1. First of all each student need to subscribe to
> > > soc at lists.osgeo.org <mailto:soc at lists.osgeo.org> (the themes
> > > connected with organizing moments) and gdal-dev at lists.osgeo.org
> > > <mailto:gdal-dev at lists.osgeo.org> (the themes about ideas,
> > > tickets, coding and community). Please don't flood both lists the
> > > same letters.
> > > 2. Next - I dig the GDAL tracker and found some tickets worth to
> > > be fixed. This work help you to understand the project structure
> > > and how it works (building, testing and so on) and help project to
> > > became better.
> > > The expected result is applied pool request in GDAL main
> > > repository at github (https://github.com/OSGeo/gdal).
> > > By the way, after pool request to this repository, the provided
> > > fixes are tested via TravisC and over test utilities.
> > > Before making pool request please test it yourself (ubuntu and
> > > windows is enough, virtualbox or preferable virtualization soft
> > > may help here).
> > > Here is the tickets I think is good for you (it's welcome if
> > > community fix this list - maybe some tickets need to be excluded
> > > or some included):
> > > - https://trac.osgeo.org/gdal/ticket/2773
> > > - https://trac.osgeo.org/gdal/ticket/5035 - Alex
> > > - https://trac.osgeo.org/gdal/ticket/5347
> > > - https://trac.osgeo.org/gdal/ticket/5592
> > > - https://trac.osgeo.org/gdal/ticket/5681
> > > - https://trac.osgeo.org/gdal/ticket/5705
> > > - https://trac.osgeo.org/gdal/ticket/6185 - Tanuj
> > > - https://trac.osgeo.org/gdal/ticket/6222
> > > - https://trac.osgeo.org/gdal/ticket/6246
> > > - https://trac.osgeo.org/gdal/ticket/6304
> > > - https://trac.osgeo.org/gdal/ticket/6316
> > > - https://trac.osgeo.org/gdal/ticket/6385
> > > I checked tickets already get by students. It's good to discuss
> > > with community how you plan to fix the tickets before start
> > > coding. Also, choose tickets carefully, we need students with good
> > > skills, so the ticket should show your potential. Some of you
> > > already choose another tickets, and this is normal too, but they
> > > need to be discussed too. For example the ticket
> > > https://trac.osgeo.org/gdal/ticket/6294 is rather controversial.
> > > 3. We need to see which ideas each of student choose, and what is
> > > a plan how to release them. You need some discussion with the
> > > community what is best way or some directions to do it. This is
> > > not spoil of the time as your ideas come as background for your
> > > project announces.
> > > It'll be nice have more details for some ideas from list
> > > https://trac.osgeo.org/gdal/wiki/SummerOfCode. The ideas #7,8,9
> > > are very briefly.
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160314/1d4c28fc/attachment-0001.html>
