[gdal-dev] GSOC 2016
Dmitry Baryshnikov bishop.dev at gmail.com
Mon Mar 21 13:19:36 PDT 2016
Hi Sarthak,
The problem is here
https://github.com/sarthak-0415/gdal/blob/trunk/gdal/frmts/postgisraster/postgisrasterdriver.cpp#L78
Your code produce situation there pszDbnameIn can be NULL. Before your
fixes, that cannot be.
So the line "CPLString osKey = pszDbnameIn;" produces crash.
Don't wait for anybody with proposal. The new GSoC site is right place
to discuss proposals.
Best regards,
     Dmitry
20.03.2016 19:41, sarthak agarwal пишет:
> Hello to all,
> Sorry for taking too long (exams and travelling).
> After running few tests -
>   * In my opinion, in Both the codes the error is not in
>     |GetConnectionInfo| function. if you replace |return true| with
>     |return false| at the last of the function it won’t fail in both
>     cases.
>   * If you run this
>     <https://github.com/sarthak-0415/gdal/commit/3e037a84e3392841cda1b4b68d75d205118caa9d>
>     and this
>     <https://github.com/sarthak-0415/gdal/commit/26e9383645b177c9e4d2ca8798a3b662901f3b63>
>     code, it won’t give you the error, the value passed here are
>     correct (NULL if that’s the case with |*ppszDbname|, the error is
>     somewhere else and I am not able to debug it.)
>   * When I am trying to configure the gdal with |enable-debug| options
>     following error comes
>     |make[1]: *** [gdalserver] Error 1 make[1]: *** Waiting for
>     unfinished jobs....
>     /home/sarthak/gsoc2016/repos/gdal/gdal/.libs/libgdal.so: undefined
>     reference to `CPLMutexHolder::CPLMutexHolder(_CPLMutex**, double,
>     char const*, int, int)' collect2: error: ld returned 1 exit status |
> My current config options are
> |./configure --prefix=/home/sarthak/gsoc2016/repos/gdal/install/
> --with-python=yes -enabl-debug=yes|
> the following error is for |gdalServer| |gdalInfo| |gdal_translate|
> and |gdaladdo|. All are having the same problem with |undefined
> reference to `CPLMutexHolder::CPLMutexHolder(_CPLMutex**, double, char
> const*, int, int)'|
> Please review the code and send me the feedback.
> Also, I would like to continue with the bug along with my GSoC
> proposal. For which I may have some ideas and would like to discuss
> the same with you.. can we talk on IRC since the deadline is in 5 days
> only.
> Regards,
> Sarthak
> On Wed, Mar 16, 2016 at 4:51 AM, Dmitry Baryshnikov
> <bishop.dev at gmail.com <mailto:bishop.dev at gmail.com>> wrote:
>     Hi Sarthak,
>     The first version is not working (do you test it?):
>     https://github.com/sarthak-0415/gdal/commit/36344cc26f23202cb289390322c1d295697136bd#diff-31df0e62d00ca09f9f11ad2f29e94b54R2541
>     Here you try to get array value with index -1. You need to set
>     ppszDbname = NULL no DB name present in input parameters.
>     The second variant is not working too:
>     >>> ds = gdal.Open('PG:')
>     terminate called after throwing an instance of 'std::logic_error'
>       what():  basic_string::_M_construct null not valid
>     In both cases there is a problem here:
>     https://github.com/sarthak-0415/gdal/blob/6264d3fc52242fdce858547cc3a0312b04fd638b/gdal/frmts/postgisraster/postgisrasterdataset.cpp#L2743
>     Also look there ppszDbname is using, as before modifications the
>     code expect that ppszDbname cannot be NULL.
>     Best regards,
>          Dmitry
>     15.03.2016 13:13, sarthak agarwal пишет:
>>     Hey Dmitry ,
>>     As discussed on the IRC yesterday,
>>     I made the changes in the code.
>>     I build two versions of the code
>>     1.
>>         The changes suggested by you (to use the old trunk code and
>>         remove the additional checks) link
>>         <https://github.com/sarthak-0415/gdal/commit/36344cc26f23202cb289390322c1d295697136bd>
>>         travis
>>         <https://travis-ci.org/sarthak-0415/gdal/builds/116070409> .
>>         a. in this version the Dbname is left empty if not provided
>>         by the user.
>>     2.
>>         The version in which we
>>         a. if the Dbname is provided by the user then ppzDbname=Dbname.
>>         b. else use the psql env var PGDATABASE
>>         c. else use the Username as the database name.
>>         d. if nothing is available then pass empty string.
>>         e link
>>         <https://github.com/sarthak-0415/gdal/commit/6264d3fc52242fdce858547cc3a0312b04fd638b>
>>         travis <https://travis-ci.org/sarthak-0415/gdal/builds/116055868>
>>     I think both version should work
>>     Regards,
>>     Sarthak
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160321/96dc1047/attachment.html>
