[gdal-dev] How to add more than one column to a shapefile using ogrinfo
aborruso
aborruso at gmail.com
Sun May 1 06:30:53 PDT 2016
Hi Jeff,
thank you.
jmckenna wrote
> I think you have to use 2 ogrinfo statements.
I know it, it works with 2 statements. Do you know why I cannot use my kind
of SQL command with all in one statement?
And what do you think about to add some note in the documentation, about the
origin of the impossibility of use this kind of command?
Thank you again
View this message in context: http://osgeo-org.1560.x6.nabble.com/How-to-add-more-than-one-column-to-a-shapefile-using-ogrinfo-tp5263730p5263745.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
