[gdal-dev] How to add more than one column to a shapefile using ogrinfo
aborruso aborruso at gmail.com
Sun May 1 10:11:36 PDT 2016
Hi Jeff,
thank you from Italy!
jmckenna wrote
> When I responded earlier I was testing and you cannot do this in one
> single ogrinfo command (so that answers your initial question).  What
> would be great, if you could add your working example to the docs: here
> is an existing wiki page for ogrinfo where you can put your example for
> adding a column through sql:
> https://trac.osgeo.org/gdal/wiki/UserDocs/OgrInfo
I have inserted my example in the wiki page:
https://trac.osgeo.org/gdal/wiki/UserDocs/OgrInfo#AddingacolumnthroughSQL
Probably I'm making a stupid question, and I'm sorry if I repeat myself: why
is not possible to use a sigle SQL statement with the adding of more than
one column?
Best regards
View this message in context: http://osgeo-org.1560.x6.nabble.com/How-to-add-more-than-one-column-to-a-shapefile-using-ogrinfo-tp5263730p5263771.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
