[gdal-dev] How to add more than one column to a shapefile using ogrinfo
aborruso
aborruso at gmail.com
Mon May 2 01:43:02 PDT 2016
On 2 May 2016 at 09:32, Rahkonen Jukka (MML) [via OSGeo.org] <
ml-node+s1560n5263838h56 at n6.nabble.com> wrote:
> It seems to me that adding a general support for adding multiple columns
> with a single request into OGR SQL dialect would require to go through
> every driver: With PostgreSQL, build SQL statement with two ADD COLUMNs,
> with Oracle use one ADD and list of column definition, with SQLite make as
> many separate ALTER TABLEs as needed, with file based formats do whatever
> is needed. That is for sure doable but feels like a big work. Users should
> also be somehow aware that certain drivers use by default some other SQL
> dialect than the OGR SQL and adding multiple columns would require
> different syntax with native dialect and with OGR SQL.
I agree, it seems big. A solution could be to use a kind of access to the
db, like the one used by ORM system (SQLAlchemy, etc.), but to build this
it's a big job too.
Thanks for this thread with all of you.
Best regard
Andrea Borruso
website: http://blog.spaziogis.it
38° 7' 48" N, 13° 21' 9" E, EPSG:4326
"cercare e saper riconoscere chi e cosa,
in mezzo all’inferno, non è inferno,
e farlo durare, e dargli spazio"
Italo Calvino
View this message in context: http://osgeo-org.1560.x6.nabble.com/How-to-add-more-than-one-column-to-a-shapefile-using-ogrinfo-tp5263730p5263853.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160502/8ccfb004/attachment.html>
