[gdal-dev] gdal_translate a VRT built on top of GeoTIFFs with NaN
Daniele Romagnoli
daniele.romagnoli at geo-solutions.it
Mon May 2 05:37:39 PDT 2016
Hi List,
I have a reprojectiion tool which creates GeoTIFFs with NoData = NaN.
I'm creating couple of GeoTIFFs with partially overlapping areas where
GeoTIFF1 has NaNs in a region and GeoTIFF2 has proper values in the same
overlapping region and viceversa (GeoTIFF2 has some NaN area while GeoTIFF1
has valid pixels for same area).
I have built a VRT on top of them and then translated into a single GeoTIFF.
However, the result has NaN in those regions.
I was hoping that the area containing NaNs would have been ignored instead,
in favor of proper values from the other file.
Is there any flag, properties or suggestions to make it working?
If I configure the reprojection tool to write NoData = -9999 and then use
gdalbuildvrt -srcnodata -9999, things are working fine.
So I'm just wondering if the same can be achieved dealing with NaN instead
of custom values.
Please, let me know.
Cheers,
Daniele
Ing. Daniele Romagnoli
Senior Software Engineer
GeoSolutions S.A.S.
Via di Montramito 3/A
55054 Massarosa (LU)
Italy
phone: +39 0584 962313
fax: +39 0584 1660272
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160502/fd67735f/attachment.html>
