[gdal-dev] gdal_translate a VRT built on top of GeoTIFFs with NaN
Daniele Romagnoli
daniele.romagnoli at geo-solutions.it
Mon May 2 05:52:41 PDT 2016
Hi Even.
Thanks for the feedback.
Sorry... I'm using GDAL 1.11.3.
I'm going to double check to make sure I didn't make any mistake.
I'll let you know.
Cheers,
Daniele
On Mon, May 2, 2016 at 2:49 PM, Even Rouault <even.rouault at spatialys.com>
wrote:
> Le lundi 02 mai 2016 14:37:39, Daniele Romagnoli a écrit :
> > Hi List,
> > I have a reprojectiion tool which creates GeoTIFFs with NoData = NaN.
> > I'm creating couple of GeoTIFFs with partially overlapping areas where
> > GeoTIFF1 has NaNs in a region and GeoTIFF2 has proper values in the same
> > overlapping region and viceversa (GeoTIFF2 has some NaN area while
> GeoTIFF1
> > has valid pixels for same area).
> > I have built a VRT on top of them and then translated into a single
> > GeoTIFF. However, the result has NaN in those regions.
> > I was hoping that the area containing NaNs would have been ignored
> instead,
> > in favor of proper values from the other file.
> > Is there any flag, properties or suggestions to make it working?
> > If I configure the reprojection tool to write NoData = -9999 and then use
> > gdalbuildvrt -srcnodata -9999, things are working fine.
> > So I'm just wondering if the same can be achieved dealing with NaN
> instead
> > of custom values.
> Daniele,
> You didn't mention which GDAL version you use. It is possible that support
> for
> NaN as a nodata value in gdalbuildvrt & the VRT driver was fixed at some
> point.
> From a quick test with trunk, it works (works with 1.11 branch as well):
> $ cat in1.asc
> ncols 3
> nrows 3
> xllcorner 440720.000000000000
> yllcorner 3750120.000000000000
> cellsize 60.000000000000
> NODATA_value nan
> 1.0 1.0 1.0
> 1.0 nan 1.0
> 1.0 1.0 1.0
> $ cat in2.asc
> ncols 3
> nrows 3
> NODATA_value nan
> nan nan nan
> nan 2.0 nan
> nan nan nan
> $ gdalbuildvrt nan.vrt in1.asc in2.asc
> $ gdal_translate nan.vrt /vsistdout/ -of aaigrid
> ncols 3
> nrows 3
> NODATA_value nan
> 1 1 1
> 1 2 1
> 1 1 1
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
Ing. Daniele Romagnoli
Senior Software Engineer
GeoSolutions S.A.S.
Via di Montramito 3/A
55054 Massarosa (LU)
Italy
phone: +39 0584 962313
fax: +39 0584 1660272
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160502/2d00c846/attachment-0001.html>
