[gdal-dev] gdal_translate a VRT built on top of GeoTIFFs with NaN
Even Rouault
even.rouault at spatialys.com
Mon May 2 06:42:24 PDT 2016
Le lundi 02 mai 2016 15:37:58, Daniele Romagnoli a écrit :
> On Mon, May 2, 2016 at 3:27 PM, Even Rouault <even.rouault at spatialys.com>
> wrote:
> > Le lundi 02 mai 2016 15:16:30, Daniele Romagnoli a écrit :
> > > Hi Even,
> > > The produced GeoTIFF doesn't contain any nodata metadata/flag/TAG.
> > > It simply has "NaN" pixels. QuantumGIS report those pixels as "nan" and
> > > OpenEV report them as 1.#QNAN so I think they are properly "recognized"
> > as
> > > NaN.
> > > I'm wondering if the GDAL utilities explicitly look for some
> > metadata/flag
> > > (as the "nodata value" in your previous ascii based sample) to do
> > > noData checks or if it's also able to recognize a NaN "binary" value
> > > inside the pixels.
> > Yes, the NaN value must be explicitly set as the nodata property of the
> > geotiff
> > file so that gdalbuildvrt can recognize it as the nodata value (similarly
> > to
> > other nodata value)
> > You can do this with gdal_translate -a_nodata nan (or gdal_edit.py
> > -a_nodata
> > nan)
> Ok. Thanks.
> I was trying to add it with "gdalbuildvrt -srcnodata nan" to avoid an
> intermediate step between my geotiff and the VRT but I was getting:
> ERROR 5: Invalid -srcnodata value
> Therefore, I had to edit the VRT by replacing the
> <ComplexSource><NODATA>-9999</NODATA></ComplexSource> with "nan" instead of
> "-9999".
> Do you know if there is any chance to let the -srcnodata parameter accept a
> String like "nan"?
Yes, this is available in the fresh new 2.1.0:
* gdalbuildvrt: accept nan as value for -srcnodata and -vrtnodata
> Cheers,
> Daniele
> > > What do you think about it?
> > > Cheers,
> > > Daniele
> > > On Mon, May 2, 2016 at 2:52 PM, Daniele Romagnoli <
> > > daniele.romagnoli at geo-solutions.it> wrote:
> > > > Hi Even.
> > > > Thanks for the feedback.
> > > > Sorry... I'm using GDAL 1.11.3.
> > > > I'm going to double check to make sure I didn't make any mistake.
> > > > I'll let you know.
> > > > Cheers,
> > > > Daniele
> > > > On Mon, May 2, 2016 at 2:49 PM, Even Rouault <
> > > > wrote:
> > > >> Le lundi 02 mai 2016 14:37:39, Daniele Romagnoli a écrit :
> > > >> > Hi List,
> > > >> > I have a reprojectiion tool which creates GeoTIFFs with NoData =
> > NaN.
> > > >> > I'm creating couple of GeoTIFFs with partially overlapping areas
> > where
> > > >> > GeoTIFF1 has NaNs in a region and GeoTIFF2 has proper values in
> > > >> > the same overlapping region and viceversa (GeoTIFF2 has some NaN
> > > >> > area while
> > > >> GeoTIFF1
> > > >> > has valid pixels for same area).
> > > >> > I have built a VRT on top of them and then translated into a
> > > >> > single GeoTIFF. However, the result has NaN in those regions.
> > > >> > I was hoping that the area containing NaNs would have been ignored
> > > >> instead,
> > > >> > in favor of proper values from the other file.
> > > >> > Is there any flag, properties or suggestions to make it working?
> > > >> > If I configure the reprojection tool to write NoData = -9999 and
> > then
> > > >> use
> > > >> > gdalbuildvrt -srcnodata -9999, things are working fine.
> > > >> > So I'm just wondering if the same can be achieved dealing with NaN
> > > >> instead
> > > >> > of custom values.
> > > >> Daniele,
> > > >> You didn't mention which GDAL version you use. It is possible that
> > > >> support for
> > > >> NaN as a nodata value in gdalbuildvrt & the VRT driver was fixed at
> > some
> > > >> point.
> > > >> From a quick test with trunk, it works (works with 1.11 branch as
> > > >> well):
> > > >> $ cat in1.asc
> > > >> ncols 3
> > > >> nrows 3
> > > >> xllcorner 440720.000000000000
> > > >> yllcorner 3750120.000000000000
> > > >> cellsize 60.000000000000
> > > >> NODATA_value nan
> > > >> 1.0 1.0 1.0
> > > >> 1.0 nan 1.0
> > > >> 1.0 1.0 1.0
> > > >> $ cat in2.asc
> > > >> ncols 3
> > > >> nrows 3
> > > >> NODATA_value nan
> > > >> nan nan nan
> > > >> nan 2.0 nan
> > > >> nan nan nan
> > > >> $ gdalbuildvrt nan.vrt in1.asc in2.asc
> > > >> $ gdal_translate nan.vrt /vsistdout/ -of aaigrid
> > > >> ncols 3
> > > >> nrows 3
> > > >> NODATA_value nan
> > > >> 1 1 1
> > > >> 1 2 1
> > > >> 1 1 1
> > > >> Even
> > > >> Spatialys - Geospatial professional services
> > > >> http://www.spatialys.com
> > > > GeoServer Professional Services from the experts! Visit
> > > > http://goo.gl/it488V for more information.
> > > > Ing. Daniele Romagnoli
> > > > Senior Software Engineer
> > > > GeoSolutions S.A.S.
> > > > Via di Montramito 3/A
> > > > 55054 Massarosa (LU)
> > > > Italy
> > > > phone: +39 0584 962313
> > > > fax: +39 0584 1660272
> > > > http://www.geo-solutions.it
> > > > http://twitter.com/geosolutions_it
> > > > *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
> > > > Le informazioni contenute in questo messaggio di posta elettronica
> > > > e/o nel/i file/s allegato/i sono da considerarsi strettamente
> > > > riservate. Il loro utilizzo è consentito esclusivamente al
> > > > destinatario del
> > messaggio,
> > > > per le finalità indicate nel messaggio stesso. Qualora riceviate
> > > > questo messaggio senza esserne il destinatario, Vi preghiamo
> > > > cortesemente di darcene notizia via e-mail e di procedere alla
> > > > distruzione del
> > messaggio
> > > > stesso, cancellandolo dal Vostro sistema. Conservare il messaggio
> > stesso,
> > > > divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo,
> > > > od utilizzarlo per finalità diverse, costituisce comportamento
> > > > contrario
> > ai
> > > > principi dettati dal D.Lgs. 196/2003.
> > > > The information in this message and/or attachments, is intended
> > > > solely for the attention and use of the named addressee(s) and may
> > > > be confidential or proprietary in nature or covered by the
> > > > provisions of privacy act (Legislative Decree June, 30 2003, no.196
> > > > - Italy's New
> > Data
> > > > Protection Code).Any use not in accord with its purpose, any
> > disclosure,
> > > > reproduction, copying, distribution, or either dissemination, either
> > > > whole or partial, is strictly forbidden except previous formal
> > > > approval of the named
> > > > addressee(s). If you are not the intended recipient, please contact
> > > > immediately the sender by telephone, fax or e-mail and delete the
> > > > information in this message that has been received in error. The
> > > > sender does not give any warranty or accept liability as the
> > > > content, accuracy or completeness of sent messages and accepts no
> > > > responsibility for changes made after they were sent or for other
> > > > risks which arise as a result of e-mail transmission, viruses, etc.
