[gdal-dev] gdal_translate a VRT built on top of GeoTIFFs with NaN
Daniele Romagnoli
daniele.romagnoli at geo-solutions.it
Mon May 2 08:07:47 PDT 2016
Thanks.
I have just opened this ticket keeping track of that:
https://trac.osgeo.org/gdal/ticket/6495#ticket
Cheers,
Daniele
On Mon, May 2, 2016 at 3:58 PM, Even Rouault <even.rouault at spatialys.com>
wrote:
> Le lundi 02 mai 2016 15:43:42, Daniele Romagnoli a écrit :
> > Cool!
> > Do you think this capability will be backported to 1.11 series too?
> Possibly if you file a ticket about that.
> > Thanks for your assistance.
> > Cheers,
> > Daniele
> > On Mon, May 2, 2016 at 3:42 PM, Even Rouault <even.rouault at spatialys.com
> > wrote:
> > > Le lundi 02 mai 2016 15:37:58, Daniele Romagnoli a écrit :
> > > > On Mon, May 2, 2016 at 3:27 PM, Even Rouault
> > > > wrote:
> > > > > Le lundi 02 mai 2016 15:16:30, Daniele Romagnoli a écrit :
> > > > > > Hi Even,
> > > > > > The produced GeoTIFF doesn't contain any nodata
> metadata/flag/TAG.
> > > > > > It simply has "NaN" pixels. QuantumGIS report those pixels as
> "nan"
> > > and
> > > > > > OpenEV report them as 1.#QNAN so I think they are properly
> > > "recognized"
> > > > > as
> > > > > > NaN.
> > > > > > I'm wondering if the GDAL utilities explicitly look for some
> > > > > metadata/flag
> > > > > > (as the "nodata value" in your previous ascii based sample) to do
> > > > > > noData checks or if it's also able to recognize a NaN "binary"
> > > > > > value inside the pixels.
> > > > > Yes, the NaN value must be explicitly set as the nodata property of
> > > > > the geotiff
> > > > > file so that gdalbuildvrt can recognize it as the nodata value
> > > (similarly
> > > > > to
> > > > > other nodata value)
> > > > > You can do this with gdal_translate -a_nodata nan (or gdal_edit.py
> > > > > -a_nodata
> > > > > nan)
> > > > Ok. Thanks.
> > > > I was trying to add it with "gdalbuildvrt -srcnodata nan" to avoid an
> > > > intermediate step between my geotiff and the VRT but I was getting:
> > > > ERROR 5: Invalid -srcnodata value
> > > > Therefore, I had to edit the VRT by replacing the
> > > > <ComplexSource><NODATA>-9999</NODATA></ComplexSource> with "nan"
> > > > instead
> > > of
> > > > "-9999".
> > > > Do you know if there is any chance to let the -srcnodata parameter
> > > accept a
> > > > String like "nan"?
> > > Yes, this is available in the fresh new 2.1.0:
> > > * gdalbuildvrt: accept nan as value for -srcnodata and -vrtnodata
> > > > Cheers,
> > > > Daniele
> > > > > > What do you think about it?
> > > > > > Cheers,
> > > > > > Daniele
> > > > > > On Mon, May 2, 2016 at 2:52 PM, Daniele Romagnoli <
> > > > > > daniele.romagnoli at geo-solutions.it> wrote:
> > > > > > > Hi Even.
> > > > > > > Thanks for the feedback.
> > > > > > > Sorry... I'm using GDAL 1.11.3.
> > > > > > > I'm going to double check to make sure I didn't make any
> mistake.
> > > > > > > I'll let you know.
> > > > > > > Cheers,
> > > > > > > Daniele
> > > > > > > On Mon, May 2, 2016 at 2:49 PM, Even Rouault <
> > > > > > > wrote:
> > > > > > >> Le lundi 02 mai 2016 14:37:39, Daniele Romagnoli a écrit :
> > > > > > >> > Hi List,
> > > > > > >> > I have a reprojectiion tool which creates GeoTIFFs with
> NoData
> > > > > NaN.
> > > > > > >> > I'm creating couple of GeoTIFFs with partially overlapping
> > > > > > >> > areas
> > > > > where
> > > > > > >> > GeoTIFF1 has NaNs in a region and GeoTIFF2 has proper values
> > > > > > >> > in the same overlapping region and viceversa (GeoTIFF2 has
> > > > > > >> > some NaN area while
> > > > > > >> GeoTIFF1
> > > > > > >> > has valid pixels for same area).
> > > > > > >> > I have built a VRT on top of them and then translated into a
> > > > > > >> > single GeoTIFF. However, the result has NaN in those
> regions.
> > > > > > >> > I was hoping that the area containing NaNs would have been
> > > ignored
> > > > > > >> instead,
> > > > > > >> > in favor of proper values from the other file.
> > > > > > >> > Is there any flag, properties or suggestions to make it
> > > > > > >> > working?
> > > > > > >> > If I configure the reprojection tool to write NoData = -9999
> > > > > > >> > and
> > > > > then
> > > > > > >> use
> > > > > > >> > gdalbuildvrt -srcnodata -9999, things are working fine.
> > > > > > >> > So I'm just wondering if the same can be achieved dealing
> with
> > > NaN
> > > > > > >> instead
> > > > > > >> > of custom values.
> > > > > > >> Daniele,
> > > > > > >> You didn't mention which GDAL version you use. It is possible
> > > > > > >> that support for
> > > > > > >> NaN as a nodata value in gdalbuildvrt & the VRT driver was
> fixed
> > > at
> > > > > some
> > > > > > >> point.
> > > > > > >> From a quick test with trunk, it works (works with 1.11
> branch
> > > > > > >> as well):
> > > > > > >> $ cat in1.asc
> > > > > > >> ncols 3
> > > > > > >> nrows 3
> > > > > > >> xllcorner 440720.000000000000
> > > > > > >> yllcorner 3750120.000000000000
> > > > > > >> cellsize 60.000000000000
> > > > > > >> NODATA_value nan
> > > > > > >> 1.0 1.0 1.0
> > > > > > >> 1.0 nan 1.0
> > > > > > >> 1.0 1.0 1.0
> > > > > > >> $ cat in2.asc
> > > > > > >> ncols 3
> > > > > > >> nrows 3
> > > > > > >> NODATA_value nan
> > > > > > >> nan nan nan
> > > > > > >> nan 2.0 nan
> > > > > > >> nan nan nan
> > > > > > >> $ gdalbuildvrt nan.vrt in1.asc in2.asc
> > > > > > >> $ gdal_translate nan.vrt /vsistdout/ -of aaigrid
> > > > > > >> ncols 3
> > > > > > >> nrows 3
> > > > > > >> NODATA_value nan
> > > > > > >> 1 1 1
> > > > > > >> 1 2 1
> > > > > > >> 1 1 1
> > > > > > >> Even
> > > > > > >> Spatialys - Geospatial professional services
> > > > > > >> http://www.spatialys.com
> > > > > > > GeoServer Professional Services from the experts! Visit
> > > > > > > http://goo.gl/it488V for more information.
> > > > > > > Ing. Daniele Romagnoli
> > > > > > > Senior Software Engineer
> > > > > > > GeoSolutions S.A.S.
> > > > > > > Via di Montramito 3/A
> > > > > > > 55054 Massarosa (LU)
> > > > > > > Italy
> > > > > > > phone: +39 0584 962313
> > > > > > > fax: +39 0584 1660272
> > > > > > > http://www.geo-solutions.it
> > > > > > > http://twitter.com/geosolutions_it
> > > > > > > *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
> > > > > > > Le informazioni contenute in questo messaggio di posta
> > > > > > > elettronica e/o nel/i file/s allegato/i sono da considerarsi
> > > > > > > strettamente riservate. Il loro utilizzo è consentito
> > > > > > > esclusivamente al destinatario del
> > > > > messaggio,
> > > > > > > per le finalità indicate nel messaggio stesso. Qualora
> riceviate
> > > > > > > questo messaggio senza esserne il destinatario, Vi preghiamo
> > > > > > > cortesemente di darcene notizia via e-mail e di procedere alla
> > > > > > > distruzione del
> > > > > messaggio
> > > > > > > stesso, cancellandolo dal Vostro sistema. Conservare il
> messaggio
> > > > > stesso,
> > > > > > > divulgarlo anche in parte, distribuirlo ad altri soggetti,
> > > copiarlo,
> > > > > > > od utilizzarlo per finalità diverse, costituisce comportamento
> > > > > > > contrario
> > > > > ai
> > > > > > > principi dettati dal D.Lgs. 196/2003.
> > > > > > > The information in this message and/or attachments, is intended
> > > > > > > solely for the attention and use of the named addressee(s) and
> > > > > > > may be confidential or proprietary in nature or covered by the
> > > > > > > provisions of privacy act (Legislative Decree June, 30 2003,
> > > > > > > no.196 - Italy's New
> > > > > Data
> > > > > > > Protection Code).Any use not in accord with its purpose, any
> > > > > disclosure,
> > > > > > > reproduction, copying, distribution, or either dissemination,
> > > either
> > > > > > > whole or partial, is strictly forbidden except previous formal
> > > > > > > approval of the named
> > > > > > > addressee(s). If you are not the intended recipient, please
> > > > > > > contact immediately the sender by telephone, fax or e-mail and
> > > > > > > delete the information in this message that has been received
> in
> > > > > > > error. The sender does not give any warranty or accept
> liability
> > > > > > > as the content, accuracy or completeness of sent messages and
> > > > > > > accepts no responsibility for changes made after they were
> sent
> > > > > > > or for other risks which arise as a result of e-mail
> > > > > > > transmission, viruses, etc.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
GeoSolutions S.A.S.
Italy
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160502/7bf310f3/attachment-0001.html>
