[gdal-dev] compile error on windows
Jeff McKenna
jmckenna at gatewaygeomatics.com
Tue May 3 10:42:57 PDT 2016
On 2016-05-03 1:36 PM, Even Rouault wrote:
> If you have the opportunity, it would be good if you could check if defining
> both _HDF5USEDLL_ and H5_BUILT_AS_DYNAMIC_LIB doesn't affect negatively your
> builds. Ideally, we'd like to have a default set of compilation flags that
> works out of the box for (almost) everybody.
It will depend how HDF5 was compiled (the cmake settings). For example,
I build the static lib of HDF5, and therefore in GDAL's nmake.opt I
point to "libhdf5.lib". In my case I therefore do not need to set
If I try to set both _HDF5USEDLL_ and H5_BUILT_AS_DYNAMIC_LIB I get 61
unresolved symbols in the linker.
Now are you understanding my grey hair comment Even? :)
I feel these notes are important to document in the buildhints wiki.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
