> The libspatialite code where the failure occurs is only executed when > spatialite is built with LOADABLE_EXTENSION undefined. Is there any > possibility that the new gpkg code depends on this being defined? > LOADABLE_EXTENSION does not appear anywhere in the GDAL source. Are you trying to link to mod_spatialite or libspatialite ? Brad
