[gdal-dev] compile error on windows
Ze Gadalo
zegdal at gmail.com
Wed May 4 11:47:35 PDT 2016
> If you have the opportunity, it would be good if you could check if
> defining
> both _HDF5USEDLL_ and H5_BUILT_AS_DYNAMIC_LIB doesn't affect negatively
> your
> builds. Ideally, we'd like to have a default set of compilation flags that
> works out of the box for (almost) everybody.
Ok, I crossed this issue also while linking against HDF5.10 and tested that
having both
works well for 5.10 and 5.8.12 (with the later _HDF5USEDLL_ was good enough)
Joaquim
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160504/25f6329a/attachment.html>
